Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya XC/CC01
Thread: How I do a body lift
Old 07-10-2009, 08:08 PM   #1
R/C Investor
sgil2001's Avatar
Default How I do a body lift
I like to do a slight body lift on my CC01's. I can get about 1/4" by using spacers up front and by doing a simple mod on the rear body post. On the rear I just cut off the existing post and drill a hole slightly above. Then I insert another post (axial leftovers) and glue it in place. A few small screws also help to hold everything in place. It's a simple way to lift the body and reduce tire rubs. I also usually hack away at the chassis around the front to reduce tire rub. What do you do to lift the body?
sgil2001 is offline   Reply With Quote
Old 07-12-2009, 11:30 AM   #2
I haven't used the stock body yet, so I have had to make custom mounts on both mine. Both mine have hinged mounts, The MAN has dual hinged, cab tilts to the front, bed tilts to the rear. The Defender tilts to the front as well.
blackfoot is offline   Reply With Quote
Old 07-15-2009, 02:29 PM   #3
I think this mod will be the next thing I do to my Jero.
FuriousCal is offline   Reply With Quote
Old 07-15-2009, 03:03 PM   #4
can you post some body on pics. i'm using the losi bashers on my jeep aswell and i would like to see how yours sits.
haynesn12 is offline   Reply With Quote
Old 07-15-2009, 07:07 PM   #5
R/C Investor
sgil2001's Avatar
I have Rock Creepers on right now. They are about the same size as the bashers (maybe a tad taller).
Old 07-15-2009, 07:41 PM   #6
how much flex like that though?
4drmopar is offline   Reply With Quote
Old 07-15-2009, 09:28 PM   #7
In between.
SACCO's Avatar
doesnt affect the suspension, body lift.
SACCO is offline   Reply With Quote
Old 07-18-2009, 06:48 PM   #8
R/C Investor
sgil2001's Avatar
I did the same body lift to my Wrangler. Here's a pic.
