07-31-2009, 10:35 AM | #1 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
| Does your steering do this?
This is my problem. When my suspension is at full compression the wheels steer out the opposite direction. Does anyone else experience this problem? Here it is with one side compressed. Then it gets stuck and I want to kill it. Hopefully someone can steer me in the right direction. |
07-31-2009, 11:09 AM | #2 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
I like your tires.;) check for binding on the linkages under the chassis, on the bottom that are covered by the lower front skid. thats the first culprit I'd check. |
07-31-2009, 03:44 PM | #3 |
Quarry Creeper Join Date: Jun 2007 Location: Maryville, TN
No, mine does not do that. Something is bent or bound or loose somewhere.
07-31-2009, 03:47 PM | #4 |
also, problem solve it logically... I think its the linkages under the chassis because it seems to affect only one wheel. the linkages under the chassis is where it goes from one bell crank (through the chassis) and splits to each wheel via those linkages. |
07-31-2009, 06:25 PM | #5 |
I have it happen from time to time but it's due to having shaved my turn stops and extra amount of steering thanks to CVDs. The knuckle/linkage gets hung up on lower a-arm. I have to shave down my a-arms to clearance the parts more. But what I'd suggest is to look at the steering when it happens. See what's binding or getting hung up.... hint, hint. |
07-31-2009, 06:27 PM | #6 |
07-31-2009, 08:44 PM | #7 |
Newbie Join Date: Jan 2005 Location: Boston
Nice mod, I think this same mod is my next project for sure.
08-01-2009, 02:35 PM | #8 |
Quarry Creeper Join Date: Jul 2009 Location: Bel Air, MD
simple, make sure BOTH balljoints on the knuckles are UNDER the arms, not on top.....
08-01-2009, 05:39 PM | #9 |
08-01-2009, 05:41 PM | #10 |
because it gives vicious "toe in" or Toe out. You shoudl REALLY look at the directions and see which way they went....
08-01-2009, 05:44 PM | #11 |
08-01-2009, 05:46 PM | #12 |
| I thought you were talking about the mod I did. I don't know how mine were originally, but the truck was fine for 2 months then it started doing that stuff. Doesn't make a difference now though.
