09-08-2009, 10:57 PM | #1 |
Newbie Join Date: Aug 2009 Location: Hart
| Pajero body size to a jeep
I purchase a pajero body off ebay complete and I found a site that sells a jeep frame and wanted to know if the jeep was about the same size as the pajero i plan on putting this on body on a frame and building a 1.9 scale truck but before i do i want to know the sizes so i know what ill have to do
09-08-2009, 11:00 PM | #2 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
they share the same chassis set to the same wheelbase so likely your idea would work.
09-08-2009, 11:20 PM | #3 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
You just move the rear shocks and lower links back one hole on the chassis to fit the Jeep body.
09-08-2009, 11:32 PM | #4 |
09-08-2009, 11:46 PM | #5 |
09-08-2009, 11:55 PM | #6 |
Well, measure your body wheelbase, center of arch to center of arch. Its my understanding the only bodies that use the longer 10.5" wb setting are the long discontinued MU and the Touareg. Pajero and Wrangler were supposed to be 9.5" wb each. If you got one handy, measure it. I'm curious now. |
09-09-2009, 01:09 AM | #7 | |
09-09-2009, 01:19 AM | #8 |
Ok, I made the right call this time The Pajero is 9 1/2" and the Jeep is 10" So yea, the lowers and shocks get moved.
09-09-2009, 02:23 AM | #9 |
Quarry Creeper Join Date: Aug 2004 Location: Louisiana
My Jeep body uses the swb, I tried the lwb but the rear tires were way off. |
09-09-2009, 02:42 AM | #10 |
Guess it just really depends on what tire your going to run. The Jeep is longer though. When I put the Jeep body on with Axial 1.9's and Out Croppers the WB was to short....
09-09-2009, 07:14 AM | #11 |
| thanks
thanks for the info yeah i plan on buying a frame from the ultimate crawler store rcrockcrawling.com with a set of d40 axles for a more scale look and plan on a 2 speed r2 tranny with the rooster crawler combo and go with 1.9 tires
09-09-2009, 08:43 AM | #12 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
The wheelbase on the CC-01 chassis are the same, 9.5" although if you are building using just the body you will need to keep the Pajero at 9.5" and it's really easy to punch out the front end to closer to 10" on the Jeep.
09-09-2009, 11:38 AM | #13 | |
Rock Stacker Join Date: Oct 2008 Location: Keene NH
I thought that the CRV was long wheelbase too, not that it matters, even if you could get one why would you want one. | |
09-09-2009, 02:24 PM | #14 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
as far as the manuals go. they are the same WB and share the same mounting holes
09-09-2009, 03:39 PM | #15 |
09-09-2009, 04:29 PM | #16 |
09-09-2009, 06:25 PM | #17 |
i do believe the jeep does have around a 10" WB. if you look at a stock CC01 jeep the front wheels are kinda far back in the front wheel wells. |
