11-07-2009, 10:26 PM | #1 |
Rock Crawler Join Date: Sep 2008 Location: Portland
| Gears jumping?
I'm having a problem with the gear for the rear axle jumping out of place. Sounds like the gear is stripping, but its just skipping. The gear isn't stripped at all, lubed up and everything. What have you guys done to fix this? Im running a 45t on 3s with no gear reduction (I know, over kill but its so much fun!) Im sure that is the reason this started but how can I fix this without a GD and/or smaller motor?
11-08-2009, 12:05 AM | #2 |
Is it in reverse that you hear it? If so, it's from the top case flexing and allowing the gears so skip. I have it happen all the time. Any well used CC-01 will have it happen. Maybe GPM will produce an aluminum top case to stop the flex issue. Are you going to be at the TTC? If so, you can see what I've done to try to stop the gear skipping noise/flexing top case. I'll have the CC-01 rig as a stand in/extra for the photos/video. |
11-08-2009, 07:43 AM | #3 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
Is this a pretty common problem? Just asking cause I have never had this happen. If it's a well used chassis, could it have anything to do with bushings versus bearings?
11-08-2009, 10:27 AM | #4 | |
11-08-2009, 03:44 PM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
i had this problem, make sure all your screws on the top plate are TIGHT especially the one right to the right of the motor
11-09-2009, 09:33 AM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
chassis flex would be my guess, but maybe take the rear locker apart and see if the screws are tight. snax had this issue a few weeks ago where the screws in the locker had been backing out and rubbing inside the housing. i am working with GPM to make a chassis brace as we speak. i just need to get my ass in gear. |
11-09-2009, 09:52 AM | #7 |
I fixed it yesterday. When it first started I tore the rear axle apart and all three screws were sitting on the bottom of the case! well that wasn't it. Yesterday I checked every last screw, three of the four gear cover screws had stripped holes. Well the only thing I had that was large enough was 6/32. So now the upper and lower gear covers are held on with 6/32 screws. Now I can drive it again!
11-10-2009, 11:55 AM | #8 | |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
11-10-2009, 12:01 PM | #9 |
11-20-2009, 06:58 PM | #10 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
I just dealt with this and found out after buying all new gears that it was that the top plate screws had stripped in the chassis...so I just used longer 3mm screws and a locknut at the bottom of the chassis and no probs since |
