11-23-2009, 03:56 PM | #1 |
Rock Stacker Join Date: Feb 2008 Location: middle of maine
| my scaler
heres my new scaler i just got in the mail its got stock motor its all stock realy sept for teh scale accessorys the tires and the body body is a new bright toy body thats been carpeted im thinken of going to a land cruiser 40 body on it diffs are locked its also got a owb that i am going to take out.... it throws the front into neutral when it spins backwards i think that would be rather annoying on the rocks... though it wont see much rock time being a trail truck im gunna put ether a 45 or a 55 turn in it body needs a lil paint in spots part of the brick wall has been chopped off im gunna werk on teh rear links too should i chop more of the brick wall off? Last edited by tdodm; 11-23-2009 at 04:15 PM. |
11-23-2009, 05:04 PM | #2 |
Pebble Pounder Join Date: Nov 2008 Location: Reno NV
I would first change out the steering for the new alum. kit that gpm is making, It will help alot. I like the use of the jeep body, May have to do that for my cc01. also a 55t motor may be a little fast still, may go with a 65 or 75 turn, I put a 85 turn in mine and still kinda fast! Just my 2 cents. Great start |
11-23-2009, 06:01 PM | #3 |
yeah im thinken about getting the gpm steering pasts... there alot of slow in the steering links
11-23-2009, 08:21 PM | #4 |
Newbie Join Date: Oct 2009 Location: kansas city
I agree on the motor specs.. i have a 55t with a 2-to-1 gear reduction and it still might be too fast. ill find out tom. if it doesnt rain..
11-23-2009, 09:02 PM | #5 |
Quarry Creeper Join Date: Oct 2009 Location: Twentynine Palms
It can be a little fast with the 55t. I've got a Fifty-Five in it and it probably does 10-12mph, which is scale 100-120mph, which is about good for a scaler, and with a good esc you'll have very fine throttle control still. Fast is relative. Speed is proportionate. Too fast, just let off the throttle a bit! |
11-24-2009, 07:26 AM | #6 |
Rock Stacker Join Date: Aug 2008 Location: DeLand
Let me know if you want to get rid of that TJ body, I could use one for a upcomming project.
11-24-2009, 01:00 PM | #7 | |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
11-24-2009, 01:24 PM | #8 |
sweet sounds like ill go fer a 55 then i want wheel speed but still have enuff torque to crawl if i can get it setup right EDIT: i also just did a front lift on it i didnt grind out the ovals in teh c hub... i coulda got more of a lift if i had... but i didnt wanna weaken it any more i gained 4-5mm Last edited by tdodm; 11-24-2009 at 02:41 PM. |
