Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Cc-01 roll over
Old 01-11-2010, 06:02 PM   #1
Default Cc-01 roll over
the cc01/xc roll over too much easily right ? anyone got a fix ? I tried 1.5oz of each wheels weight in front and 1oz in each rear and still same...
milenko_78 is offline   Reply With Quote
Old 01-11-2010, 06:26 PM   #2
0 0
romulus22's Avatar
mine is pretty planted. but then again i dont really expect it to have the same capabilities as lesser scale trucks.
but yeah put some weight in the wheels and move stuff toward the front
romulus22 is offline   Reply With Quote
Old 01-11-2010, 07:14 PM   #3
post a pic of your cc01/xc. Mine are really planted and they all have a really low COG due to everything being in the chassis (thus being lower than the tops of the tires mostly).
p-
pantablo is offline   Reply With Quote
Old 01-12-2010, 12:42 AM   #4
here some pics of my cc01 --->
Old 01-12-2010, 01:34 AM   #5
Lower the body atleast an inch and see how it works.
BBCorvette18 is offline   Reply With Quote
Old 01-12-2010, 11:12 AM   #6
I joined the Band!
X2 your body is sitting way to high.
grimgard is offline   Reply With Quote
Old 01-12-2010, 04:44 PM   #7
jeebus, quite the body lift you have there ... mine does seem to roll over easily, maybe i'm not pushing it to its limits :/
phoenixtroy is offline   Reply With Quote
Old 01-13-2010, 05:22 PM   #8
yes I know these hard body weight alot more then the lexan one but I cant down lift the body the front tire will rub on it
Old 01-13-2010, 06:10 PM   #9
I joined the Band!
Trim the fenders or get a body that will fit better.
Old 01-13-2010, 06:20 PM   #10
cartronicshn's Avatar
X2 on this advice, i have a jero and a fj cruiser body on my cc-o1 rigs which i think have taller cog and they don't roll that easily .
cartronicshn is offline   Reply With Quote
Old 01-13-2010, 08:21 PM   #11
I think my hardbody CC-01 is right on par with my lexan lid 1.9 scale rig. Actually, I think the CC-01 might be better at off camber situations.
Have to remember that the CC-01 has very limited suspension movement when comparing to a SCX10 based rig. They are also narrower too.
Are you running full stock stiff foams in those tires? My Pro-lines look almost flat when my CC-01 is sitting on flat ground... Might try a different foam setup to allow the tires to have a bit more "give" and to lessen the bounce effect that seems to make the CC-01 based rig to roll faster.
.... drop that body too... I can see it's underwear.
toyofast is offline   Reply With Quote
Old 01-15-2010, 03:58 AM   #12
I trimmed the front fenders and the front bumpers corner I have now my bodyto sit lower about 6 or 7mm and still roll over easily I see some videos of the cc01 on youtube and this truck seem to roll easily is not good for crawling or trial I think only trail running
body lowered shot :
toyofast : I run no foam at all in the 4 tires and no hole in the rims.
Old 01-17-2010, 09:53 PM   #13
ya they seem to roll over fairly easily... add more weight to the wheels.
I maxxed out my 12 OZ limit. I think I put 60% of the weight in front and 40% in the rear
Flowmastered87GL is offline   Reply With Quote
Old 01-17-2010, 11:49 PM   #14
body lowered shot :
It still looks a bit high. The bottom of the body should sit at the bottom of the tub chassis. If you need to cut some more you can always cover your cuts with some fender flares.
I would just buy a Lexan Unimog body and be done with it.
Grumpster1980 is offline   Reply With Quote
Old 01-23-2010, 01:57 PM   #15
Grumpster1980 : I lowered it again and it still roll over easy I tried a 80 grams only lexan body from my 1/8 buggy for test and still roll easily I think we need to live with :-(
Old 01-24-2010, 08:51 AM   #16
what degree are you side hilling?? My S10 that i'm building on (still) I tested it the other day on the walk in front and it ran at a 45 degree side hill no prob. Set up looks like yours--placement anyway. maybe its your shocks, what are you running? Could they be compressing and rolling the body over then the whole rig??? I have no holes or foams in my tires either.
squatch71 is offline   Reply With Quote
Old 01-27-2010, 03:03 PM   #17
i think mine tips over easy... but then again i might be expecting to much
traxxas4fun is offline   Reply With Quote
