01-11-2010, 06:02 PM | #1 |
Newbie Join Date: Nov 2009 Location: Canada
| Cc-01 roll over
the cc01/xc roll over too much easily right ? anyone got a fix ? I tried 1.5oz of each wheels weight in front and 1oz in each rear and still same...
01-11-2010, 06:26 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
mine is pretty planted. but then again i dont really expect it to have the same capabilities as lesser scale trucks. but yeah put some weight in the wheels and move stuff toward the front |
01-11-2010, 07:14 PM | #3 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
post a pic of your cc01/xc. Mine are really planted and they all have a really low COG due to everything being in the chassis (thus being lower than the tops of the tires mostly). p- |
01-12-2010, 12:42 AM | #4 |
here some pics of my cc01 ---> Last edited by milenko_78; 01-12-2010 at 12:49 AM. |
01-12-2010, 01:34 AM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: Yacolt, wa
Lower the body atleast an inch and see how it works. |
01-12-2010, 11:12 AM | #6 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
X2 your body is sitting way to high.
01-12-2010, 04:44 PM | #7 |
Rock Stacker Join Date: Jan 2010 Location: Ohio
jeebus, quite the body lift you have there ... mine does seem to roll over easily, maybe i'm not pushing it to its limits :/
01-13-2010, 05:22 PM | #8 |
yes I know these hard body weight alot more then the lexan one but I cant down lift the body the front tire will rub on it |
01-13-2010, 06:10 PM | #9 |
01-13-2010, 06:20 PM | #10 |
01-13-2010, 08:21 PM | #11 |
I think my hardbody CC-01 is right on par with my lexan lid 1.9 scale rig. Actually, I think the CC-01 might be better at off camber situations. Have to remember that the CC-01 has very limited suspension movement when comparing to a SCX10 based rig. They are also narrower too. Are you running full stock stiff foams in those tires? My Pro-lines look almost flat when my CC-01 is sitting on flat ground... Might try a different foam setup to allow the tires to have a bit more "give" and to lessen the bounce effect that seems to make the CC-01 based rig to roll faster. .... drop that body too... I can see it's underwear. |
01-15-2010, 03:58 AM | #12 |
I trimmed the front fenders and the front bumpers corner I have now my bodyto sit lower about 6 or 7mm and still roll over easily I see some videos of the cc01 on youtube and this truck seem to roll easily is not good for crawling or trial I think only trail running body lowered shot : toyofast : I run no foam at all in the 4 tires and no hole in the rims. Last edited by milenko_78; 01-15-2010 at 07:01 PM. |
01-17-2010, 09:53 PM | #13 |
Quarry Creeper Join Date: Aug 2009 Location: Portland
ya they seem to roll over fairly easily... add more weight to the wheels. I maxxed out my 12 OZ limit. I think I put 60% of the weight in front and 40% in the rear |
01-17-2010, 11:49 PM | #14 | |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
I would just buy a Lexan Unimog body and be done with it. | |
01-23-2010, 01:57 PM | #15 |
| Grumpster1980 : I lowered it again and it still roll over easy I tried a 80 grams only lexan body from my 1/8 buggy for test and still roll easily I think we need to live with :-(
01-24-2010, 08:51 AM | #16 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
what degree are you side hilling?? My S10 that i'm building on (still) I tested it the other day on the walk in front and it ran at a 45 degree side hill no prob. Set up looks like yours--placement anyway. maybe its your shocks, what are you running? Could they be compressing and rolling the body over then the whole rig??? I have no holes or foams in my tires either.
01-27-2010, 03:03 PM | #17 |
Quarry Creeper Join Date: Apr 2009 Location: Indianapolis Indiana
i think mine tips over easy... but then again i might be expecting to much
