02-06-2010, 12:48 AM | #1 |
Rock Stacker Join Date: Jul 2008 Location: huntsville
| my new cc01 land cruiser!
hi there guys just got my tamiya cc01 land cruiser and been reading some of the thread here in rccrawler forum. Just wondering if you can help me with some useful guides on mods and performance of the kit?? Thanks in advance!
02-06-2010, 08:09 AM | #2 |
Rock Stacker Join Date: Jul 2009 Location: Philippines
Hey sid15, great to hear that you've got your CC01 already! Actually, there's a whole lot you can do to mod the CC01, but the most basic, I guess, would be to lock both diffs and get better tires. You've got the steering problem covered since your gpm kit is on the way. A high torque servo like hitec will also give you better steering performance. Ball bearings would also work great. Suspension lifts, changing the rear links, changing shocks, there is really so so much more you can do, but the ones i initially mentioned would basically make your rig run better on the trails. Just keep checking out the rigs and mods here and you'll get so many ideas. Have fun with your CC01! |
02-06-2010, 09:19 AM | #3 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
Post up some pictures! These CC-01's are good out of the box not much to do to them other than buy the GPM steering kit.
02-06-2010, 10:40 AM | #4 |
| re
tnx mix. yup surely i will post some pictures of my kit! can't wait to run it outside!
02-06-2010, 06:10 PM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: North Alabama
Looking forward to seeing the pics. I've recently built one. I'm starting to try a few simple mods...... These are before any mods: http://www.nehp.net/~jimw/crawler/crawlers%20026.jpg http://www.nehp.net/~jimw/crawler/crawlers%20027.jpg http://www.nehp.net/~jimw/crawler/crawlers%20028.jpg I'll post more pics after some mods. Jim |
02-07-2010, 01:22 AM | #6 |
is it a must to have ball bearing on cc 01??? because i didn't order any yet.... just wanna ask before i assemble my kit... thanks..
02-07-2010, 01:05 PM | #7 |
More pics after a few mods this morning. New tires, rear suspension mod from "BLACKFOOT", front bearings, and locked the front diff. http://www.nehp.net/~jimw/toyota/ ...work in progress..... Jim |
02-07-2010, 01:22 PM | #8 |
Pebble Pounder Join Date: Mar 2009 Location: Grants Pass, OR
Is the new FJ40 CC-01's body mounted like that with the posts through the body? I kind of liked the way the old ones were mounted.
02-07-2010, 02:07 PM | #9 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| Yes, the lexan shell, CC-01 bodys mount just like any other lexan shell. With a little modification it would not be hard to fab up some new mounts with something like velcro though.
02-08-2010, 07:52 AM | #10 |
Oh dang, I didn't know the new CC01's had lexan bodies. Why the heck are they so much more expensive?!?
02-08-2010, 08:44 AM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
you can mount the body without post holes, if you use velcro or rare earth magnets, dont know about the price, but these bodys look great with a bit of tlc mine is mounted with velcro at front and back, and some internal bodymounts I made from styrene on the inner sides. that is mine, though its a custom chassis not cc01 |
02-08-2010, 10:08 PM | #12 |
02-09-2010, 09:45 PM | #13 |
02-09-2010, 10:34 PM | #14 |
Pebble Pounder Join Date: Oct 2009 Location: northridge
10-04-2010, 05:35 PM | #15 | |
Newbie Join Date: Sep 2010 Location: england
10-04-2010, 10:05 PM | #16 |
Pebble Pounder Join Date: Jul 2010 Location: Bay Area
| People have had success making links using axial links or traxxas links, rod ends are both 3mm size(not sure tho), hope this helps |
10-04-2010, 11:44 PM | #17 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
That pic is a custom chassis and not a CC01 just so you are aware. GPM make a rear arm kit and I highly recommend it but you can also make you own as a lot of people have done on here using some threaded rod and link ends.
10-06-2010, 10:06 PM | #18 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
x2 on its up to you on the body you use...Mine is mounted with styrene posts with screws from under the chassis...no screws on top..and pretty stock these rigs do run over lots of stuff... vid http://www.youtube.com/watch?v=Zf12bXLAetU bearings are not a must...but sooner or later the bushings will wear out...I got a set of bearings from the bay, ran me only like 10 bucks.. I make my own links using all thread and tube and traxxas rod end kit #1942. Last edited by squatch71; 10-06-2010 at 10:09 PM. |
10-09-2010, 05:54 PM | #19 |
Quarry Creeper Join Date: Oct 2009 Location: Twentynine Palms
^--That rig is begging for 1.55s and DGs.
10-12-2010, 02:11 PM | #20 |
Quarry Creeper Join Date: Jul 2008 Location: Kaufman
Same issue with mine, there at the end of the vid. Not enough front weight and a tad top heavy.
