Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: ?*?cc-01 diff question???
Old 03-28-2010, 06:27 PM   #1
Default ?*?cc-01 diff question???
whats the easiest way to lock the tamiya cc-01 front diff? I cant stand open diff in the front.
macattac-1968 is offline   Reply With Quote
Old 03-28-2010, 08:50 PM   #2
fill it with hot glue or jb weld...
i cant remember if you can move one of spider gears to lock it or not...
i added thin washers behind a couple of the spider gears, this almost locked the diff but when it gets into a bind the other tire will unload
Konaman is offline   Reply With Quote
Old 03-28-2010, 09:39 PM   #3
Take an extra spider gear and drop it in between two of the ones on the "Y" shaft in the diff.
fixed13 is offline   Reply With Quote
Old 03-29-2010, 10:36 AM   #4
Search and you will find your answers. The easiest way is to take one of the spider gears out and drop it in between the other two. This will lock it and if you even want it open again just put the gear back.
Grumpster1980 is offline   Reply With Quote
Old 03-29-2010, 08:35 PM   #5
Like so
Positronic is offline   Reply With Quote
Old 03-30-2010, 05:33 AM   #6
It is simpler to close diff's cover.
DUsoft is offline   Reply With Quote
Old 04-01-2010, 09:15 AM   #7
On the lookout for Rocks
constantmotion's Avatar
3 Spider gears are sufficient enough.
constantmotion is offline   Reply With Quote
Old 04-02-2010, 08:46 PM   #8
Go for a limited-slip front diff.
It's tight enough to be effective, but you don't loose steering.
rampage is offline   Reply With Quote
