07-31-2010, 03:37 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: bay
| front suspension lift
Hi guys i have just got cc01 used. and was going through the mods and i do not see this one. the truck has losi mrc tires on it. they work but looking for more ground clearance and would like to run taller tires. thank sivad
07-31-2010, 04:02 PM | #2 |
Rock Crawler Join Date: Jun 2010 Location: Forsyth County, Georgia
Get some spacers and put them on before you screw the front skid plate down. You will need longer screws though becuase the original ones won't be long enough. By doing this you will have room for new wheels and bigger tires, aswell as room for better and bigger shocks |
07-31-2010, 04:58 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Yea I used some aluminum sheet about 3/8" thick I think and just cut it to where they fit in the little spaces inbetween the skid and where it screws in on the bottom of the chassis. Should give you a mild lift depending on how thick the stuff you use is. Combine that with a body lift and your good for some 4" or a little taller tires. On top are the bushings that come with the kit that you can use or then the aluminum I used is on the bottom. Sorry pic is blurry. Last edited by BGGruff; 07-31-2010 at 05:00 PM. |
07-31-2010, 06:22 PM | #4 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
I used Axial alloy spacers available at any hobby store. They work great. Plus you get to to choose colors! |
08-01-2010, 12:52 AM | #5 |
Pebble Pounder Join Date: Jul 2010 Location: Bay Area
08-01-2010, 01:01 AM | #6 |
thanks guys that's what i was looking for post pic's soon as im done
08-01-2010, 03:21 PM | #7 |
Quarry Creeper Join Date: Aug 2009 Location: Portland
you can also just increase the drop angle of the A arms too. Both my rigs are setup that way. Just take the arms off and dremel the heck out of them so they droop more. Then either put on longer front shocks or put spacers at the top. Sorry the best picture I have.... its actually pretty old, but you can see the spacer at the top and new shock. |
08-02-2010, 06:09 PM | #8 |
ok so i used 6mm spacers and this what i got still looking for more lift. i did move the shocks down 10 mm thank that helped here is a pic. (GPM stuff is on the way ) |
08-06-2010, 01:41 PM | #9 |
Quarry Creeper Join Date: Jan 2006 Location: Wales
thats a fair amount of lift but if you go much more your going to have to fab up some other parts such as new camber links to allow your arms to move the full amount of your lift. You'll also need to open up the slot on the hub carrier to allow the dogbone to move up and down these little rigs get pretty top heavy with a lot of lift I run 4.0" tires on mine with about 3/4" of lift using longer shock shafts in the stock shock bodies I also did all the control arm mods to get the maximum amount of travel. Have Fun!! Here's a pic it isn't great but it's the best I have I built this rig quite a while ago.. |
