01-26-2011, 11:44 PM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Brentwood
| Integy Lathe in CC-01?
anyone have one in theres? i tried putting mine in but it sits sideways so the pinion isnt set right. everything else looks fine, anyone had this problem? |
01-27-2011, 06:03 AM | #2 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
Sounds like you mounted the motor in the wrong holes on the motor plate. There is a set for 16t pinion and a set for 20t pinion. Hope this helps. Cheers Jarrod |
01-27-2011, 06:38 AM | #3 |
And make sure the motor mount isn't upside down. It only goes in one way.
01-27-2011, 09:52 AM | #4 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
I have a lathe motor in mines and it sits just fine. As others have said, make sure the mount is in correctly.
01-27-2011, 12:32 PM | #5 |
01-27-2011, 12:32 PM | #6 |
01-27-2011, 02:04 PM | #7 |
figured it out, one of the battery tabs that you soidier the wire on was hitting the chassis.
