Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: CC01 shocks
Old 11-27-2011, 12:45 AM   #1
Default CC01 shocks
Hey guys,
I've replaced the rear suspension of my CC with the Junfac 4-link and i am using the GPM shocks.But i would like it to have a bit more articulation in the rear,i've seen some guys use other shocks,wich ones would be the best replacements?
Thanks
minicrawler1 is offline   Reply With Quote
Old 11-27-2011, 02:03 AM   #2
i use CR-01 shocks running 100% droop on a GPM 4Link set up and i get a huge amount of flex for a CC, if you want alot of flex i would recommend these, or any other 90-110mm long shocks
Landcruiser 110 is offline   Reply With Quote
Old 11-27-2011, 02:09 AM   #3
Thanks,i'll try using the super leaky shocks from my CR on my CC!
I may be wrong?But i think some guys use Losi shocks as well?
Do you have a pic of your CC flexing?
Thanks
Old 11-27-2011, 04:27 AM   #4
Yes I do in my thread, it's on the bottom of the second page of CC-01 section, and it's called CC-01 FJ40 Touring Rig, also I don't run very much oil at all in the shocks, only enough so they slide smoothly and this way they don't leak, hope this helps
Old 11-27-2011, 04:48 AM   #5
I am running a pair of HPI Super shocks on mine and love them. I was running the RC10 gold’s prior but find the HPI ones a lot smoother. I really like the junfac kit too. Good choice! Shock Length is 70mm-103mm.
Here is a couple pictures of my set-up.
SFC K is offline   Reply With Quote
