01-28-2013, 11:01 PM | #1 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Front Hubs for 1.5" Wheels?
I've seen a bunch of stuff on fitting 1.5" wheels to the front end. It either involved modifying the wheels or running steelies. What I'm wondering is if anyone's ever fitted different C-hubs and steering knuckles. As long as the distance from outdrive to inner bearing remained constant, it should work. Time for some late night hacking! |
01-28-2013, 11:32 PM | #2 |
| Re: Front Hubs for 1.5" Wheels?
Short answer: Yes. I test fitted a set of Tamiya TL01/M03 C hubs, knuckles and stub axles, using the stock CC-01 dogbones. They fit like they belonged on there. Geometry on the C hubs appeared dead on. This tells me that the newer M05/06 stuff would probably fit as well, even if the C is a few mm shorter. A nice bonus is that you gain around 5mm of track width on each side. If you use the M chassis parts, you need the proper size bearings for the knuckles. If you want to use CVDs, It appears a standard Tamiya touring car length would do the trick. Yeehaw! |
01-29-2013, 03:09 PM | #3 |
Rock Crawler Join Date: Jul 2011 Location: USA
I was able to file a very small amount off my c's and my 1.55's fit without rubbing.
01-29-2013, 04:03 PM | #4 |
Thought about that as well. How about a wide tread kit? They add 3-4mm per side by pushing the wheels out on longer axles and hex fittings.
01-29-2013, 10:17 PM | #5 |
that would also work as long as you dont mind the added width. In my case I only had to file a small amount, if it was more i would have used a widener. |
01-29-2013, 10:25 PM | #6 |
Rock Crawler Join Date: Jul 2012 Location: Brisbane, Australia
The stock plastic rims will rub big time, but you should be fine with aftermarket 1.55 beadlocks.
01-30-2013, 12:55 PM | #7 |
I've got some Tamiya M04 Giulia wheels I want to use. As mentioned, I'm looking to avoid the usual route/expense of beadlocks. (Though the Junfacs are pretty affordable!) I love my 1.9 Topcad/Integy beadlocks. Just want another option. |
01-30-2013, 02:35 PM | #8 |
I have a set of the GMade beadlocks and they are awesome. Never came unlocked and they took plenty of abuse. They are easily the best beadlocks for the price.
Front Hubs for 1.5" Wheels? - Similar Threads | ||||
Help with front hubs | gixrsixr | Axial AX-10 Scorpion | 15 | 03-22-2011 02:45 AM |
