Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Thin 12mm hex adapters
Old 02-02-2013, 08:36 AM   #1
Default Thin 12mm hex adapters
Anybody know of any thinner than stock hex adapters? My new wheels and tires rub the Wrangler hard body so if I can bring the wheel in some it will clear the fenders (which I don't want to cut) axial Exo hexes are slightly thinner and help a little. Anybody else do this and know of any hexes?
Steve Hipsley is offline   Reply With Quote
Old 02-02-2013, 05:06 PM   #2
Default Re: Thin 12mm hex adapters
I picked some up off e-bay. that are only about 4mm thick. I think they were from an SCX-10. I really wish I could remember where I found them at. That's what I'm using on mine.
Abavuso is offline   Reply With Quote
Old 02-02-2013, 06:07 PM   #3
the stock ones are soft plastic, cant you just file them down? you might need a spacer for the wheel nut so it doesn't bottom out the threads tho
edit: lol just read the title, my bad
Koldham is offline   Reply With Quote
Old 02-02-2013, 07:36 PM   #4
58_Willys's Avatar
I knew I had seen them somewhere...made by Integy...
I did this...and it works pretty good although, I think it would work better if it's done with the aluminum hex without the set screw setup.
Keep in mind, that using a thinner hex may require some grinding on the hex on the back of the wheel. If not, it may rub on the end of the axle.
58_Willys is offline   Reply With Quote
Old 02-02-2013, 09:02 PM   #5
I had a set of thin plastic ones that came with a set of 2.2 RPM revolver wheels a long time ago. At laest thats where I think they came from. But a quick tower search and I found these... TowerHobbies.com | Integy Hex Wheel Hub 12mm 4mm Thickness Blue 1/10 Drift ...granted they are integy brand...but they're just hexes...I hope integy can get at least those correct.
gr33nlemon is offline   Reply With Quote
Old 02-03-2013, 12:06 AM   #6
Look at on road racing stuff. I just picked some 4mm alloy ones made by 3Racing. Cheap and effective.
monkeyracing is offline   Reply With Quote
Old 02-03-2013, 11:35 AM   #7
That's actually what I did last night. I have some old plastic Axial hexes that came with the original AX10 so I filed one of those down as a test. Works for now.
Old 02-03-2013, 11:35 AM   #8
Thanks for all the info!
Thin 12mm hex adapters - Similar Threads
Where to get 12mm to 17mm hex adapters? InFlames General Crawlers 5 04-30-2009 08:50 PM
12mm Aluminum Hex Adapters ccampb04 Tamiya TLT Crawlers 3 04-02-2005 07:00 PM
12mm hex adapters for Twin/Mad Force?? kingcobra Kyosho Crawlers 2 01-23-2005 07:18 PM
