02-02-2013, 08:36 AM | #1 |
Quarry Creeper Join Date: May 2010 Location: rock hill
| Thin 12mm hex adapters
Anybody know of any thinner than stock hex adapters? My new wheels and tires rub the Wrangler hard body so if I can bring the wheel in some it will clear the fenders (which I don't want to cut) axial Exo hexes are slightly thinner and help a little. Anybody else do this and know of any hexes?
02-02-2013, 05:06 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
| Re: Thin 12mm hex adapters
I picked some up off e-bay. that are only about 4mm thick. I think they were from an SCX-10. I really wish I could remember where I found them at. That's what I'm using on mine.
02-02-2013, 06:07 PM | #3 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
the stock ones are soft plastic, cant you just file them down? you might need a spacer for the wheel nut so it doesn't bottom out the threads tho edit: lol just read the title, my bad Last edited by Koldham; 02-02-2013 at 06:10 PM. |
02-02-2013, 07:36 PM | #4 | ||
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
| Re: Thin 12mm hex adapters Quote:
Keep in mind, that using a thinner hex may require some grinding on the hex on the back of the wheel. If not, it may rub on the end of the axle. | ||
02-02-2013, 09:02 PM | #5 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
I had a set of thin plastic ones that came with a set of 2.2 RPM revolver wheels a long time ago. At laest thats where I think they came from. But a quick tower search and I found these... TowerHobbies.com | Integy Hex Wheel Hub 12mm 4mm Thickness Blue 1/10 Drift ...granted they are integy brand...but they're just hexes...I hope integy can get at least those correct.
02-03-2013, 12:06 AM | #6 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Look at on road racing stuff. I just picked some 4mm alloy ones made by 3Racing. Cheap and effective.
02-03-2013, 11:35 AM | #7 |
| Re: Thin 12mm hex adapters That's actually what I did last night. I have some old plastic Axial hexes that came with the original AX10 so I filed one of those down as a test. Works for now.
02-03-2013, 11:35 AM | #8 |
Thanks for all the info!
Thin 12mm hex adapters - Similar Threads | ||||
Where to get 12mm to 17mm hex adapters? | InFlames | General Crawlers | 5 | 04-30-2009 08:50 PM |
12mm Aluminum Hex Adapters | ccampb04 | Tamiya TLT Crawlers | 3 | 04-02-2005 07:00 PM |
12mm hex adapters for Twin/Mad Force?? | kingcobra | Kyosho Crawlers | 2 | 01-23-2005 07:18 PM |
