02-17-2014, 10:08 AM | #1 |
Newbie Join Date: Feb 2014 Location: southampton
| New to the crawling world and need help
I'm a noob in the crawling world, but not to rc in general. I want to start my first build with a scale crawler and was looking at the cc01 because I thought it was cool. For now, I'm on a strict budget and the cc01 seems to be the cheapest. I was planning on buying either the landcruiser or bronco, and putting these in it. I need your approval (the crawler community) of weather or not this setup is ok to run in a stock car. Vxl 3m brushless system from the traxxas minis, but I will only run it on a 7.2v battery. Im asking, is the combo im using ok to use in a stock cc01 kit and what else do i need to do out of the box to make it perform better. I want to stay on as low of a budget as possible, the reason why im using that brushless is because its from my old 1/16. |
02-17-2014, 04:31 PM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Hi. If that motor is the smaller, 380 (26mm diameter) sized can I think it is, you'll have trouble fitting it to a CC01. The CC uses a standard 540 (35mm diameter) sized motor. That said, this motor would be a bit fast for a CC01. A 4000kv motor in a CC. Would be like an F1 engine in a lawn mower. You should shop for a cheap, sensorless motor of around 2000kv or less, or better yet, look for a cheap or used brushed system with a 55t or higher motor. eBay and rc4wd both have some great deals, as does the for sale section on this site. I hope that helps. Sorry it wasn't better news.
02-21-2014, 08:29 AM | #3 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
| Re: New to the crawling world and need help
what monkey said!! sell off the VXL system and pick up a 50 to 65t motor and a decent ESC w/ drag brake ( like a Axial AE3) and you'll have a very capable rig. Theres a lot of reasons to NOT use the VXL system, it wont mount up w/o building some type of adapter, its waaaaay too fast and you'll be spending your $$ on replacement parts like gears and such, not really water proof (wont live long if submerged), very poor low speed control, no drag brake (means the truck will roll when off throttle) ect. ect. Just my 2 cents worth...Welcome to the forum! read some posts in the CC01 section and you'll figure out what mods you will need for your style driving and the terrain you'll be running, theres some pretty smart folks that hang out here and plenty of info available
02-23-2014, 12:49 PM | #4 |
Well, I ordered the truck and such, it should be here soon, ill keep posted on the build. My overall plan is: Hobbyking radio and reciever XL-5 and stock motor (being replaced in the future with either a GRU or a 55t RC4WD motor) GPM suspension links, I figured it was cheaper than Junfac RC4WD 1.9 White steel rims on 1.9 rock creepers Make my own trail bumper Magic link mod Traxxas Waterproof servo Boca full bearing kit That's really it. I was looking on other forums and people were talking about chopping the "Brick wall"? Someone inform me on this. I presume its the giant plastic block under the bumper. Please inform me of whats the best options for me. I plan on doing medium crawling and a bit of trailing, I'm new to this. |
New to the crawling world and need help - Similar Threads | ||||
New to the rc crawling world | Ryno0413 | Newbie General | 11 | 06-24-2013 07:30 AM |
New to the world of crawling! | Hammer! | General Crawlers | 5 | 01-30-2013 03:22 AM |
New to the world of crawling | Hammer! | Electronics | 0 | 01-28-2013 10:09 PM |
I'm New to the crawling world | Tin Bender | Losi Mini-Rock Crawler | 10 | 08-11-2010 07:39 PM |
New to the crawling world.... | JarheadRCGuy | Axial AX-10 Scorpion | 15 | 02-10-2009 03:42 AM |
