03-08-2015, 05:16 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| CC01 scale attemp number one
Been tinkering with, Moggie. Yes I name my toys Put in the GRU, got rid of the brick, added some weight to the front, Stack in place, new battery cover, air and fuel tanks. All the stupid working lights and some front suspension modifications along with moving the upper shock mounts. 27T motor and as soon as the parts get here I'll be gearing it up a little, adding rear aluminum links and replacing the lovely stock steering Got my Sawback kit this week and robbed the tires and wheels from it for the Mog. Also put a set of 12mm wheel spacers on it. Best thig I've done yet. And yes I have a new camera on order, and that's a .22 shell for the filler neck on the fuel tank. |
03-09-2015, 07:41 AM | #2 |
Newbie Join Date: Jan 2015 Location: Amherst
| Re: CC01 scale attemp number one
Are the weights up front instead of wheel weights? What pinion is on the GRU? Nice work. Just curious. why did you cut the front off? I am working on a cc01 now and found a way, I think, the make the parts on the steering arms work with very little modification. Time will tell! Keep the information on this build coming.
03-09-2015, 07:24 PM | #3 | |
| Re: CC01 scale attemp number one Quote:
03-09-2015, 10:14 PM | #4 |
Found out the hard way that a 20 tooth pinion with the HPI gru creates problems. in order to put the 20 on you have to rotate the motor/gru and this caused the gru to hit the steering servo. I'm sure most of the CC01 guys know this, but failed to tell me lol. Also, I got the GPM spur gear today. Figured I'd try it. It's good for more noise and a tranny full of aluminum shavings. That was a lesson learned And I finally found some tires that look Mogish. Hope they work! Put a HR gear cover on the bottom. Not sure why... Cause it's pretty? And I'm still waiting on my new camera |
03-10-2015, 10:41 AM | #5 | |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
03-10-2015, 05:55 PM | #6 |
I had issues with the end of the spur that runs on the lower gear. I replaced the lower gear for the drive shaft with a steel gear and it seems to be holding, but now the plastic locker setup that came with it is stripped. Think I may stack the metal diff gears in the rear and fill it with J.B weld.
03-10-2015, 06:00 PM | #7 |
did some digging and found this. How to pitch a 32 at your XC - Scale 4x4 R/C Forums |
03-11-2015, 05:35 AM | #8 |
Your info is great. How much weight did you put in the front and rear? Your physics on mass, rotation and torque make sense! Keep the info coming as you progress with this build.
03-11-2015, 06:20 PM | #9 |
So far I've only added 2oz to the front of the cassis. Actually the rotating mass probably doesn't apply to something with the wheel speed of my Unimog. But in my opinion 6oz in each tire of a larger higher powered crawler might cause a little loss of torque and strain on the drivetrain, but the weight in the tires helps keep the center of gravity lower and the weight is under the suspension. It's a little bit of give and take. And most of the guy's that have been crawling for a long time, and know way more than I do tend to weight the tires from what I've seen. Anyway, I got a bag of factory gears in the mail today, and finding the very back screw was stripped and allowing the tranny cover to lift under a heavy load, and replacing all the tranny cover screws with machine thread screws should fix that problem. Gotta fix the rear diff and I should be good for a couple more days I'm only running 2s Lipos in mine. It's slow, but the wheel speed is perfect when crawling through the rough stuff, and the slow crawl ability is crazy. Seems more scale to me. I've got a trail rig I'm building for bashing and one of these days I'm going to build my Sawback in a attempt to build a true scaler. This CC01 is kind of an practice rig I'm still new to the crawler scene myself, so don't go butcher your CC01 based on what I say lol. Search this place and you'll find the answer to every question you could ever have. Last edited by Jeepiac; 03-12-2015 at 06:30 PM. |
03-12-2015, 11:32 AM | #10 |
Pebble Pounder Join Date: Sep 2012 Location: Netherlands
I'm diggin' those wheel nuts! Do you mind sharing who makes them?
03-12-2015, 06:27 PM | #11 |
| Re: CC01 scale attemp number one |
03-12-2015, 06:40 PM | #12 |
HCCrawler, here's a link with tons of info! Been posted on here before, but just in case you haven't seen it yet. CC01 tech thread. - RC Rock Crawlers & Scalers @ URC Forums |
09-03-2015, 07:54 PM | #13 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
and now the little mog that could ....belongs to somebody else i will post up some more when i get a chance |
CC01 scale attemp number one - Similar Threads | ||||
1st Video attemp | Freakshow185 | Videos! | 6 | 08-15-2013 07:30 AM |
And reason number 5434564322 to go to the Scale nats! | XSRCdesign | Competitions | 4 | 05-22-2009 10:46 PM |
My attemp at a tuber | BOWTIE | Tamiya TLT Crawlers | 27 | 05-15-2007 11:53 AM |
Scale Jeep chassis - TLT first attemp | rcguy | 2.2 Scale Rigs | 9 | 09-26-2006 03:31 PM |
