03-28-2015, 05:31 PM | #1 |
Newbie Join Date: Jan 2015 Location: Amherst
| Metal Gears
Any thoughts on whether metal gears are a necessity for the CC01 to run in comps? They are expensive and if not used, the money could go to other items.
03-29-2015, 09:50 AM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
| Re: Metal Gears
battery size, motor size/type, tire size and driving style are all key factors here. Whats your setup?
03-29-2015, 10:50 AM | #3 |
| Re: Metal Gears
1.9 wheels and tires, HPI GRU, 45t brushed crawler motor, 20t pinion, longer WB, 2000 NIMH or 3000 NIMH.
03-29-2015, 01:24 PM | #4 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| Re: Metal Gears
I'm running a HPI gru with a 27T, 16 tooth pinion and Nimh packs and I've had gear troubles. So far the front diff is the only thing I haven't trashed. I think it's all in how rough you're going to be on it. I seem to have a talent for killing the rear diff myself.
03-30-2015, 01:30 PM | #5 |
| Re: Metal Gears
wow, I must be a light throttle driver I run a 3s 5000 lipo, 85t brushed and 1.55 mtz's. The only gears I've needed were the spur and pinion. which were a pita to fit. Once I learned about the shims though its been good!
03-30-2015, 06:07 PM | #6 |
| Re: Metal Gears
I don't know what the deal was with mine. Beginning to think I don't know how to build worth a crap. After the last go around with the gears, shimming the spur and putting in the metal lower gear for the rear drive all seems good but I don't trust it yet. If it hold together I'm going to try a 20T to get a little more wheel speed. I don't think loosing a little torque is going to be a problem with a GRU. Might be easier on the drivetrain.
04-16-2015, 04:07 PM | #7 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
| Re: Metal Gears
Hpi gru put out almost unstoppable torque and take a half second to actually slow to a stop after you drop the throttle so if your in a bind is a half second too Iate. blew out a gear set on mine for that reason mind you was running a traxxas 12t Sent from my iPhone using Tapatalk |
04-20-2015, 08:08 AM | #8 |
| Re: Metal Gears
Never thought of the extra gears continuing to spin after you let off the throttle. That split second in the wrong spot could surely break stuff.
05-14-2015, 08:59 AM | #9 |
Quarry Creeper Join Date: Aug 2014 Location: home
| Re: Metal Gears
can't remember where i saw it... maybe on one of osrc's build threads..you can fit a whole bushing in the rear axle to stop the factory diff from wearing so fast...i just put it in and upgraded the whole diff at the same time..can't remember the brand but the gears are steel
05-14-2015, 09:06 AM | #10 |
| Re: Metal Gears
If the gear cover is not cinched down tightly, you can get "gear pops" (as I call them) - use machine screws on the gear cover ilo the stock tapping screws. Helps a bit. Or even better, drill out the screw holes in the chassis that hold down the gear cover to 3mm and use longer screws and locknuts on the bottom of the chassis. Cover's not going anywhere in that case.
05-14-2015, 06:16 PM | #11 | |
| Re: Metal Gears Quote:
Metal Gears - Similar Threads | ||||
"Metal Gears" Equals "Pot Metal Gears" | Robb | Duratrax Cliff Climber | 18 | 05-20-2009 07:09 PM |
Metal Gears | vltchkr | Duratrax Cliff Climber | 6 | 12-01-2008 08:58 PM |
metal gears | igotnylint | General Crawlers | 13 | 03-22-2007 07:02 AM |
