03-06-2016, 11:42 AM | #1 |
Newbie Join Date: Feb 2014 Location: Tri-Cities
| Snowtrail's hardbody Pajero CC-01 Build
Well, I'm new to the forum but not rc. Have had my cc-01 for almost two years now, and it sat due to forces outside my control til now. I initially painted it my high school colors, but now want to redo it to a "recovery/search and rescue"-esque vehicle, sand ramps, roof rack with rescue gear, etc. I have decided on a mettalic flake of my school colors (purple and gold). The next step is getting some performance upgrades into it, and i would like recommendations on the following: Steering: hot racing (mine is still stock and little slop, but why not replace?) Cvds: go with tamiya? Tires: i have some 1.55 rims from rc4wd, but need tires still. Motor: running stock silver can still, but i think it might be going out the door soon. Esc: if i chance upon an axial ae-2 for cheap, this is what i will run. I have already done the brick mod, made a skidplate for the front, and shaved the front hubs for more steering. Any help would be greatly appreciated! |
03-06-2016, 01:14 PM | #2 |
Pebble Pounder Join Date: Nov 2007 Location: Grand Rapids
| Re: Snowtrail's hardbody Pajero CC-01 Build
i also started to build up a cc01 that i got in trade. i have heard that the rc4wd 1.55 mud thrasher work great and keep the size down to where it still looks good with the cc01. one thing that i plan on doing is trying to get alittle longer travel in the back with little bigger/longer shocks. i see you plan on doing the steering upgrade. i think those are the couple big things people say to do and other then that just run it and upgrade when stuff breaks or what not. OH if you want to go slower get a GRU (gear ruduction unit) have heard those help out a lot. |
03-06-2016, 03:22 PM | #3 |
Pebble Pounder Join Date: Nov 2015 Location: Northern NJ
I just installed the GPM steering and did not have any of the issues that I have seen reported on this site. I have no slop in the steering at all. The only slop left is caused by slop in the suspension. I have all Integy C-Hub, lower A arm, Knuckle. Either steering setup should be a big improvement. As part of my steering upgrade, I also put GPM links on the servo connection and 2 out to the wheels. The stock are just sloppy. I also put an RC4WD 80t brushed motor on.....Nice and slow...I am not looking for ground speed, but it does go fast enough that I would worry about turning too fast and scratching up body work. The motor was $9....it is a sealed can, polished bushing.....for the price, I can replace it pretty often. They have a nice selection at 35t,45t,55t,65t,and 80t. For the price, you can afford to try different winds to find the one that suits you. I have the Tamiya CVDs. They appear to be very strong and fit properly. You can't go wrong with this. The last important upgrade, is the rear links. I haven't the $ to replace them yet, but the stock plastic links look pretty fragile to me. Last edited by Chumley54; 03-07-2016 at 08:59 AM. |
03-07-2016, 08:15 AM | #4 |
Thanks for the replies! I have thought about the rear links as well. Possibly the junfac set i think is the maker. I like my wheel speed but might go to a 35t.
03-10-2016, 06:06 AM | #5 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
I have the Junfac 4-link kit on one of my CC-01's, I like it a lot. Also, might want to consider a 55t motor, I think that is more appropriate for the CC-01. If you need more wheel speed, run a small 3s and you will still retain your low speed control. Here Is a good economical setup; rc4wd 55t motor, Axial AE-5 esc, small venom 2100mah 3s lipo. |
03-10-2016, 09:23 AM | #6 |
I am running a 3S, 3000 MAH Lipo with a RC4WD 85T brushed motor... Since I am not looking for racing speeds, it is fast enough... I have a bunch of Monster trucks if I want speed....The CC01 is a lot more realistic at a slower pace. Easier to control with lower speed too... |
03-10-2016, 07:47 PM | #7 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
I'm running an Axial 55t, AE-2 and a 2s 2200mAh. I was using 1.55 Mud Thrashers but just got some new Dick Cepek Fun Countrys, just a hair taller than the Mud Thrashers, but about 1/4" (or thereabouts) narrower, and in the X2SS compound.
03-13-2016, 08:09 PM | #8 | |
I want either the thrashers or MTZs. Do you still have the thrashers? Last edited by THX_138; 05-03-2016 at 09:34 AM. Reason: Merge, posts a minute apart | |
03-14-2016, 01:17 PM | #9 |
| Re: Snowtrail's hardbody Pajero CC-01 Build |
03-15-2016, 06:12 AM | #10 |
Rock Stacker Join Date: Apr 2006 Location: Asheville
| Re: Snowtrail's hardbody Pajero CC-01 Build The shorter 1.9 MTZ is a nice tire, still alot of sidewall and height for a CC-01 when trying to maintain a "stockish" look. The 1.55 MTZ's look great but ground clearance is an issue. Just depends on what you're after.
03-17-2016, 07:46 PM | #11 |
I plan to keep my truck stock and little to no cuting of the body. so the 1.55 thrashers will be my tire of choice i think. as it sits currently. not much but it has always been fun to drive on the few chances i have had.(hopefully to change that soon!) Last edited by THX_138; 05-03-2016 at 09:37 AM. |
03-18-2016, 05:37 AM | #12 |
Looks good, makes me want to get mine up and running now. Sent from my SM-N920V using Tapatalk |
03-18-2016, 10:48 AM | #13 |
03-18-2016, 10:50 AM | #14 |
All the body stuff plus the rear body post and a Pinion to be running, there are other stuff I want like different tires, upgrade steering, and links. Sent from my SM-N920V using Tapatalk |
Tags |
cc-01, pajero, recovery, rescue, tamiya |
Snowtrail's hardbody Pajero CC-01 Build - Similar Threads | ||||
Best way to mount a hardbody to the Pajero? | trailduster79 | Tamiya XC/CC01 | 2 | 07-25-2009 08:01 AM |
