Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: compatible body mounts
Old 08-27-2019, 02:28 PM   #1
Default compatible body mounts
Hi everybody.
The time has come to ressurrect my CC01. I bought it around 25 years ago with all I had saved for years.
It has spent around 15 years stored and "decapitated", as it is missing its wrangler body.
I plan on dismantling and greasing all gears, and even throw some money at certain hop-up parts.
But of course I will need a body, and there goes my question:
what bodies (availables) should be compatible with the Wrangler mounts?
If not, are specific mounts sold together with the body?
I would like to change to Defender or Pajero. I guess it will be easier, being SWB all three.
VRvander is offline   Reply With Quote
Old 08-28-2019, 12:42 AM   #2
Default Re: compatible body mounts
if you buy a similar shaped body you just have make the holes in the body to fit. anything else that fits might just need shorter or longer body posts, and you can just swap these over. most bodies come without holes so you can make the holes where you like. various lengths of posts for the cc01 are available on eBay.
Sent from my SM-G930F using Tapatalk
The_Italian_job is offline   Reply With Quote
Old 08-28-2019, 08:05 AM   #3
Use any body you want and get some heavy duty magnets and come up with your own mounting bracket
Sent from my SM-G965U using Tapatalk
aiden102408 is offline   Reply With Quote
Old 08-28-2019, 01:21 PM   #4
or use Velcro strips. I made up mounting brackets and then just put Velcro on the bodies. no holes and easy to take on and when changing batteries.
Old 08-31-2019, 08:27 AM   #5
Thank you for your replies.
@The_Italian_job the thing is, the Wrangler body on this CC01 didn't use body posts, but rear "pinholes". The body stays attached by two rear pins and a front tab. I believe the Pajero uses this same system and would therefore not need more stuff. Velcro strips sounds good.
@aiden102408 I guess I could try that too.
Old 08-31-2019, 11:21 AM   #6
Sorry . Didn't realise. All mine had body posts. I tend to buy cheap kamtec lwb bodies.
Sent from my SM-T820 using Tapatalk
compatible body mounts - Similar Threads
TRX 4 compatible '72 chev p/u body adam.baxter Traxxas Crawlers 4 12-20-2018 11:15 PM
Scx10 upper rear shock mounts compatible? Metric HPI Venture 4 06-12-2018 12:39 PM
Side Body Mounts vs. Top Body Mounts notez2beat Paint and Body 3 12-15-2009 07:47 AM
