03-22-2011, 11:59 AM | #1001 |
03-22-2011, 12:08 PM | #1002 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
03-22-2011, 12:14 PM | #1003 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
03-22-2011, 12:21 PM | #1004 |
Here's another thing I've been working on lately... Adjustable from 3oz to 10oz of sub axle weight per side With this setup, I swithced to a 1" SLW front wheel with a 725 offset hub. I've had to readjust my foams since I removed the wrap of sticky weights from inside the tire. I tried to compensate by using a stiffer inner foam for the Shamrock Showdown in St. George over the weekend, and it was pretty terrible Once I get the foams dialed back in, I feel that this setup will be amazing. I also swapped in an RcBro's aluminum motor clamp to keep the motor from moving around when I'm flying through the courses. I've never had any major problems with the stock clamp, but the aluminum one definitely adds some piece of mind. Last edited by Del Monte; 03-22-2011 at 12:45 PM. |
03-22-2011, 12:25 PM | #1005 | |
In general, I like to use full tires on smooth rock, and cut tires on rough or loose rock. It seems that full and cut tires both work better once they're broken in. My favorite set is actually the tires from the 2010 German Natonals... and they probably have 250 battery packs on them now | |
03-22-2011, 01:08 PM | #1006 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
03-22-2011, 01:36 PM | #1007 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Weight system looks great! Are those Vp LH's sluggs? Also.. What is that on the motor? |
03-22-2011, 02:44 PM | #1008 | |
they're actually these guys http://www.horizonhobby.com/Products...ProdID=PIN3915 same weight as the DH slugs but a little smaller than an LH slug | |
03-22-2011, 02:53 PM | #1009 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
03-22-2011, 02:54 PM | #1010 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Mmm....Tungsten.... Quote:
03-22-2011, 02:56 PM | #1011 |
Rock Crawler Join Date: Oct 2008 Location: Italy
how the weight is fixed to knuckles? compliments for this up grade!! |
03-22-2011, 03:00 PM | #1012 |
Rigs lookin good jake! Cant wait to molest it at ECC |
03-22-2011, 04:22 PM | #1013 | |
Pebble Pounder Join Date: Mar 2010 Location: Danbury
I may be asking a stupid question but what ESC is that? Ryan | |
03-22-2011, 04:33 PM | #1014 | |
Sorry Jake. I meant your front shocks. | |
03-22-2011, 04:35 PM | #1015 |
| No worries, the front shocks are mounted the same way. I just had a pic of the rear shocks handy so I used it The ESC is just a standard Xcelorin Crawler ESC with this heatsink installed http://www.horizonhobby.com/Products...rodID=LOSB9352 |
03-22-2011, 04:39 PM | #1016 |
What's up with that rear electronics tray? |
03-22-2011, 07:46 PM | #1017 |
03-24-2011, 04:30 PM | #1018 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Great idea Jake! Got that inner beadlock figured out yet? Nice work.
03-24-2011, 09:42 PM | #1019 |
03-26-2011, 04:31 PM | #1020 |
Nice convenient spot for the bind plug... Haha
