06-19-2009, 02:52 PM | #1 |
Newbie Join Date: Jul 2005 Location: Springville, UT
| kulangflow's LCC (pics/vids)
Thought I'd share a couple of my crawlers. I'm mainly sharing the LCC, so I figured this would be a good place for it. Losi Comp Crawler has a Mamba Max, CCBEC, Titan 550 motor (13t pinion), 3s 1700 mAh lipo, 7995 and 82MG servos. For the LCC, I haven't had any of the problems people have apparently been having. I re-greased the gears with Gear Jelly, removed the extra two shims from the diffs (they inadvertently installed 2 too many), and limited the steering EPA to 90%. I also re-loctited all the CVD screws/pins. No issues. I did try a 35t motor at first, but it just wasn't up to the task. It would stall out and smoke if stressed. The Titan 21T 550 is handling it like a champ now. MRC has a mini-Nino chassis and Eritex Heavies with blue-Claws, aluminum shocks, and a Li-Saver LVC. I took some onboard video. It's currently processing, but here's the link for when it's done: http://www.youtube.com/watch?v=bml9aUhHCUY&fmt=22. A second video is uploading, and it will show the wheelspeed. Good times. |
06-19-2009, 03:37 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
I really like those lil cameras. Gonna have to get one soon........ |
06-19-2009, 03:45 PM | #3 |
Here's part 2: http://www.youtube.com/watch?v=opqXyvVbmno&fmt=22 At the end of part 2, you'll see the wheelspeed of the Titan 550 with a 13T pinion on 3s. @Rocksmith: Thanks for the comment and the Gear Jelly! I haven't had any heat problems in the diffs. |
