06-21-2009, 07:53 AM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
| June 20th First Comp....UPDATED 8-9-09
Well my LCC worked GREAT at the first comp I used it at. The only issue I had was motor heat. I smoked the motor 2 times but it kept on working. Once the comp was complete I was driving around doing some different lines and the motor smoked out a 3rd and final time. It was so HOT that before I could pull it from the truck the pinion had melted the spur. I was running a 27t arm in a 35t can with a 14t pinion. I broke 1 cv axle but that was from a pretty hard fall onto 1 wheel. Other than those issues I was really impreesed with my LCC and took 1st place at the comp. So all in all a GREAT event for myself seeing as how I usually finish mid-pack.... .. to Losi for building an AWESOME rig..... Last edited by 1rcmonster; 08-10-2009 at 05:24 AM. |
06-21-2009, 08:56 AM | #2 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
Congrats on the comp results! Just gotta get those motor temps under control, lucky thing the 3rd smokin' was after the comp! |
06-21-2009, 12:28 PM | #3 |
Newbie Join Date: Jun 2009 Location: In My Own Mind
Good job at the comp. What motor are you going to use next? maybe a brushless. I still can't make up my mind what to put in mine.
06-21-2009, 03:29 PM | #4 |
Pebble Pounder Join Date: Mar 2008 Location: paradise
sweet good for you must be a good weekend for losi cuse i had a grate first comp with mine too im pretty shure i won but woint know till results are poasted
06-21-2009, 03:59 PM | #5 |
Rock Crawler Join Date: Apr 2005 Location: Humble
Was that 2s or 3s? and glad to know the losi survived the comp with minimal damage. I'm planning to comp mine on the 28th with minimal tweaks, kinda of a baseline. After that I think I'm going custom chassis. |
06-22-2009, 04:30 PM | #6 |
The motor I am going to run next is the Traxxas Titan with a 12t pinion. I am using an Xcite 11.1v 1350mah. I was very happy with the end results other than the motor issues, hope the Titan will help there.
06-22-2009, 04:45 PM | #7 |
| That good to hear about the Xcite batterys, I have 1300 3s packs I love them them.
07-05-2009, 11:23 AM | #8 |
| Updates....
Well I replaced my spur gear today and installed the Titan with a 12t pinion. What a difference. There is much more punch right off the start and the wheel speed is good. I was running for a good 45 minutes and the motor never even came close to HOT as before. Temped the motor and it was at 125 degrees. The more the truck breaks in the better it is getting. I am learning how to use the dig more and when to use it and the LCC just keeps impressing me.
07-05-2009, 01:17 PM | #9 | |
Rock Crawler Join Date: Sep 2008 Location: Oroville, CA
Thats awesome to hear cause its the setup im going to try. Thanks for posting your findings! Good job in the comp too! | |
07-05-2009, 01:28 PM | #10 |
As stated, you really need to learn to use the dig. At first I was using it but now I am USING it. When doing tight turns I was staying in the throttle too long, building excess heat in the motor. Now I have learned to blip the throttle when needing to turn tightly, this cuts down on the heat. Also when the axles, mainly the front, seems bound that is a good time to use the dig. You can still get in the throttle when needed but I feel as tho prolonged high revs is what was causing alot of my heat issues.
07-05-2009, 02:11 PM | #11 |
What about a heat sink on the motor?
07-05-2009, 03:04 PM | #12 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
07-05-2009, 03:23 PM | #13 |
I think im going to try that. How hot is normal for the 550 motor?
07-05-2009, 05:20 PM | #14 |
The 550 is a pretty tight fit. I have been running Emaxxes for years and have never run heatsinks. We beat the hell out them too. Usaully running at Monster Truck shows and running multiple packs thru them continuosly. Have never burnt up a 550 motor but have smoked a few battery packs. It was about 80 degrees here today and no wind where we were crawling so I think the 125 degree motor temp is very good. When I ran the 27t motor it got EXTREMELY hot in a very short time and it was cooler and windy as well. So far the 550 is the best motor. I started with a 35t...SMOKE, then the 27t arm in the 35t can...SMOKE. After a 45 minute runtime and a temp of 125 I am liking this combo. |
07-06-2009, 10:47 AM | #15 |
Rock Crawler Join Date: Apr 2009 Location: NorCal
07-06-2009, 11:01 AM | #16 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
| The most proliferated photo in the LCC Forum The fan on the motor does make a difference. Friend and I were running our LCC's yesterday with the same setups, on the same rocks doing the same lines, etc... I measured my motor temp @ 121f and his was 140f... 20degree difference. I run a fan, he does not, and I think I'm more heavy handed on the throttle than he is as well (I've broken 3cvd's, he's broken none!). I should mention that the Ambient temp outside when we were crawling was 113f so the temps of the motors being relative to the ambient was not very hot at all. |
07-06-2009, 11:06 AM | #17 |
07-06-2009, 12:30 PM | #18 |
07-06-2009, 01:48 PM | #19 |
113F outside!!! Thats way to hot to be outdoors haha.
07-06-2009, 02:27 PM | #20 | |
and yeah, 113f is hot | |
