06-24-2009, 11:10 AM | #1 |
Rock Crawler Join Date: Sep 2008 Location: Oroville, CA
| Tranny lube..
I hear 2 stories.... Some say lube the tranny and others say it effects the dig operation... Can i get some feeedback plz guys.
06-24-2009, 11:17 AM | #2 |
Rich says that you don't have to lube the gears but he said it doesn't hurt it. I can see it effecting dig operation if you use too much. Personally I wouldn't bother. If they were all metal gears, then yes, I'd lube 'em.
06-24-2009, 11:32 AM | #3 |
i put a small bit on the dig forks and slider shaft. other then that just a dab on the gears inside the case and nothing on the spur and slipper gears. no need to gob it in there. |
06-24-2009, 12:39 PM | #4 |
Ok thanks guys.
06-24-2009, 01:07 PM | #5 |
I just dabbed a tiny bit on the main shaft to eliminate the little friction of the disconnects. I did this before I found the bent "e" clip causing the non-shift. As stated before, Rich told me that it wouldn't hurt.
06-24-2009, 01:16 PM | #6 |
Rock Crawler Join Date: Apr 2009 Location: NorCal
I run mine dry,,,remember that oil is a dust magnet,,,,,
06-24-2009, 01:38 PM | #7 |
I only ask cause the guy I am getting it from has already lubed the tranny and diffs with mobil synthetic something.... My friend said he had to take all his lube out for the dig to operate right.
06-24-2009, 09:31 PM | #8 |
RCC Addict Join Date: Apr 2004 Location: 5280
I used Dry Ice race lube on mine, just like I do in my B4's Stealth. Can't hurt and it doesn't attract dust like grease. Smooth as butter |
