09-10-2009, 02:08 AM | #1 |
Rock Stacker Join Date: Apr 2008 Location: Mtarfa
| Motor for the lcc?
What motor do you suggest for a lcc with cc sidewinder and 3C lipo? Something which gives me alot of wheel spin and enough torque. If you have any vids of your rigs and tell me what setup you have would help me alot... What do you think about this one TRAXXAS TITAN 550 MOTOR, 21 TURN http://www.ckrccrawlers.com/shop/ind...oducts_id=2121 do you think it will be too fast? maybe stupid but I dont know what gearing the losi has ind the g-box and diffs Last edited by pitass; 09-10-2009 at 02:15 AM. |
09-10-2009, 02:39 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
The tranny is almost 1:1. Yes the Titan will work. There are several threads in here that will answer all of your motor/ESC questions. I started one when it first came out that is about 8 pages long now.....Search is your friend |
09-10-2009, 03:26 AM | #3 |
What do you think about this setup? Do I need anything else, maybe a bec or someting? Last edited by pitass; 09-10-2009 at 06:57 AM. |
09-10-2009, 06:07 AM | #4 |
I would ditch the "Wiggle Servo" and pick up the Hobbico CS170 servo (also recommend the Hitec 7995TG, JR 8711, Airtronic 94780M). The Tekin HotWire isn't needed. You can do all the necessary program at the ESC...it's easy. |
09-10-2009, 06:25 AM | #5 |
Updated the cart, thanks bdw any pinion suggestions? |
09-10-2009, 06:38 AM | #6 |
You don't need the servo horn. The losi kit comes with servos horns that fit all the brand names out there. I would pick up variety of pinions 13-16 tooth. Yes I would add a bec. |
09-10-2009, 06:59 AM | #7 |
updated again, I already have a 48 pitch 12 tooth pinion so that makes 12, 14, 16... hope thats all I need lol, price is getting higher and higher but the setup is getting better and better also xD Thanks for all your help |
09-10-2009, 07:18 AM | #8 |
Newbie Join Date: Mar 2009 Location: Kalispell
I would look at your original ESC choice. The Sidewinder is a great speed control, 3s capable and BL capable as well if you ever put it in another rig. Its not a sensored system so it won't run a BL in a crawler. One of its downfalls is a weak drag brake but with a Losi that's not needed. They are about 30 bucks cheaper tham the Tekin.
09-10-2009, 07:41 AM | #9 |
RCC Addict Join Date: Jan 2009 Location: O.C
You can get much cheaper batteries on www.valuehobby.com and ebay. Just a suggestion.
09-10-2009, 08:08 AM | #10 |
Rock Stacker Join Date: Jun 2009 Location: Portland
I'm running a maxx product 480 size 11t puller with my sidewinder on 3s. 12t pinion and a fan above it. Lots of wheelspeed. Runs at 130-140 for temps.
09-10-2009, 09:58 AM | #11 |
Newbie Join Date: Jun 2009 Location: Yuba City
Amainhobbies.com has the losi for $219. right know. with the upgraded CVD's
09-11-2009, 10:36 AM | #12 |
Quarry Creeper Join Date: Apr 2008 Location: Clay, Alabama
I think there is some question about running the Titan on 3 cells with the FXr - a buddy of mine does it, and loves it - but the FXr says "down to 35 turns" on 3cell. Just something to think about. I run the Integy V11 35T on 3 cells with the FXr, and I'm pretty happy with it - 13t pinion. My 35 got a fresh cut comm and little hotter brushes which helped a lot. Not the best comm cut out of the box. |
09-11-2009, 11:55 AM | #13 |
Quarry Creeper Join Date: Feb 2008 Location: EAST TN WHERE SHINE IS FREE
x2 on amain way cheap er |
09-12-2009, 10:57 PM | #14 |
Pebble Pounder Join Date: Oct 2008 Location: here
Just checked amain and the price was 284.-- . Must of we t back up ???????
09-13-2009, 05:07 AM | #15 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
09-13-2009, 06:47 AM | #16 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I am running an LCC with the Titan motor and 12t pinion. Using a CC Sidewinder and Xcite 1300 3s battery. This combo is working very well for me and helped me to win our summer series here in North Dakota.
09-13-2009, 02:40 PM | #17 |
| are you running a 21t or 23t titan ? I may have to run the combo you are for little while till I can my Tekin RS pro fixed. Awesome that it is working out for your wins! |
09-13-2009, 03:14 PM | #18 |
Rock Crawler Join Date: Sep 2008 Location: Oroville, CA
I am running the 23T with a 12T pinion. Seems to work very well. The only complaint I have is from stop to slow crawl its a little jumpy.
09-13-2009, 03:51 PM | #19 |
09-13-2009, 10:55 PM | #20 |
