10-11-2009, 08:19 AM | #1 |
Rock Stacker Join Date: Sep 2008 Location: Gilmer, Tx
| Wheel weights on the LCC MOA setup
For those of you runningthe Eritex MOA setup, what wheel weight setups have you tried with success? Since the motor is on the axle, should I use less lighter wheels on front, rear, both, etc? Let me know. Thanks!
10-11-2009, 09:43 AM | #2 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
My fronts weight 14oz per wheel and tire, and my rear weight just under 8 oz. It seem to work well for me but I have not had it that long. Total weight is still under 6 lbs.
10-11-2009, 09:49 AM | #3 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
i added 6 oz to the fronts and 3 oz the the rear on the stockers for a light set. and my heavys are 12.5 oz ft and 9oz rear total tire wheel foam.
10-11-2009, 10:41 AM | #4 |
Holdin my 40oz. Join Date: May 2008 Location: Somewhere in Colorado
I am just curious about something. Usually MOA rigs have a lot of weight in the wheels....why is that? With their low CG and the weight of the motors on the axles i would think they would need hardly any weight in the wheels. My LCC runs like 5 oz. up front and nothing in the rear with stock plastic rims. and climbs like a champ! I even run only 3 1/2 oz in the front depending on the course design. I think if I were gonna run a MOA conversion kit I would start out with my lighter set-up. I like reading these threads on the MOA stuff.
