10-21-2009, 09:20 PM | #1 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
| Chassis Lean
New to the this crawling thing, but after hitting some rocks w/some articulation my chassis stays somewhat leaned. Is this the suspension binding? Do I need more preload? Stiffer springs? My setup as far as suspension is bone stock.
10-21-2009, 09:27 PM | #2 |
see the nuts that hold the springs? tighten them down simple as that but some do get stiffer springs for the rear but i didnt feel my cralwer needed it i try to keep them evenly cranked down and the front softer than the rear
10-21-2009, 10:57 PM | #3 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Yah I would just work on adjusting the shocks..Should be able to get rid of the lean..And as 2500hd said..Keep the front a little softer than the rear.
10-22-2009, 12:01 AM | #4 |
Thanks..I'll give that a shot. I ordered some stiffer springs for the back.
10-22-2009, 07:52 AM | #5 |
Pebble Pounder Join Date: May 2008 Location: Kalispell Montana
As long as everything is moving nice and free, the chassis leaning shouldn't be an issue. I have found out running a soft setup on the rig works extremely well. I went softer on the rear springs to greys with outboarded rear shocks and found it had no negative effects. White springs will work too. Going stiffer rears made the suspension unload on vertical climbs.
10-22-2009, 04:26 PM | #6 |
I got this big ol wall for incline tests and tunes and whatnot and the chassis leaning was an issue/concern for me. Using what I had on hand I put Losi orange springs on and the lean was all but dialed out and the truck flexes as much and as freely as it did with the white springs on it. If the chassis is at full lean there's no more suspension travel left and it if encounters something that might need suspension travel, it's over. That being said I couldn't stand the look of the orange springs with my yellow body, so I put the whites back on hoping I won't encounter such an obstacle at this weekend's event. Could just paint the springs, or find something similar in black I guess... |
10-22-2009, 05:37 PM | #7 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
Make some covers for the spings I made some for mine, they are nice. Keep the dirt off the shafts for the most part and look nice.
10-22-2009, 06:10 PM | #8 |
| Are you running the MOA kit on yours? Heck no. Don't like em. Looks goofy. If anything I'd flat black the outside of the body and call it a Halloween paint job. Take it trick or treating. |
10-22-2009, 06:46 PM | #9 |
Rock Crawler Join Date: Mar 2004 Location: Albany
run yellow springs
10-22-2009, 07:18 PM | #10 |
No point really.
10-22-2009, 07:44 PM | #11 |
I know but you didnt like the color atleast they would match your body better then the orange or white
10-22-2009, 10:21 PM | #12 |
10-22-2009, 10:32 PM | #13 | |
10-22-2009, 10:38 PM | #14 |
Newbie Join Date: Oct 2009 Location: Bergination
Are your shocks full of oil? Is something sticking? Maybe you need stiffer springs?
10-23-2009, 02:05 PM | #15 | ||
And me being one to experiment, or tweak, I'll have to try the greys in back. | ||
10-23-2009, 02:25 PM | #16 |
Pebble Pounder Join Date: Aug 2005 Location: Napa, CA
10-23-2009, 02:28 PM | #17 |
Yeah, old picture. Those gotta be really soft! |
