11-07-2009, 08:18 AM | #1 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
| Lower link rod ends
Does anyone else have a lot of slop on the 17* rod ends? My lcc is all but new and I have quite a bit. I have put some fuel tubing between the ends at the chassis side to keep them from popping off, but that does not help the slop. Also i have already pulled one off the link caused by a 18" fall off of my couch. There was only 1/4" of 5-40 thread sticking out of the link. The rod end could easily take 1/2" threaded into it. I tried to remove the threaded rod from the link to replace it with a longer one, but I was unsuccessful. I will probably end up making custom links because of this, but would really like to get the stock pieces up to snuff. Any tips would be great, also if anyone has found a better rod end with a close to stock angle, please post up! Thanks, Rob Last edited by chevellian; 11-08-2009 at 06:46 PM. |
11-07-2009, 08:55 AM | #2 |
Rock Stacker Join Date: Mar 2009 Location: UPSTATE
seemes like a lot of people started to ues these also i just bought a set to try out. and pritty darn cheep http://www3.towerhobbies.com/cgi-bin...?&I=LXJJ81&P=7 |
11-07-2009, 12:16 PM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: Iowa
I put a piece of fuel tube between the links. I cut it long enough that I had to squash it down to get the link mounts to fit back into the skid plate. Since I have done that, I have never had one pop off and it has taken a few hard tumbles down the rock pile. The fuel tube doesn't seem to affect articulation any either. |
11-07-2009, 01:11 PM | #4 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Alternatives coming soon!!! |
11-07-2009, 03:22 PM | #5 |
| That's good news, Can't wait for more details The 17* 4-40 combination doesn't give you any choices. Although you probably could get away without the bend. Last edited by chevellian; 11-08-2009 at 06:22 PM. |
11-07-2009, 03:38 PM | #6 |
| I will get some details posted soon..I have a couple Losi inspired items in the works right now..Trying to get everything buttoned down this week coming,so I can get production started ASAP..
11-08-2009, 01:32 PM | #7 |
Rock Stacker Join Date: Jun 2009 Location: Portland
if you are talking about the chassis side. I just used some shock orings between them. haven't popped out yet.
11-08-2009, 06:04 PM | #8 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
i did the same with shock o rings and works great. Also the thread pitch is a 5-40 in the links and rod ends mine would not come out either so i got new ones and made delrin links.
11-08-2009, 06:44 PM | #9 | ||
11-08-2009, 06:45 PM | #10 |
11-08-2009, 08:24 PM | #11 |
here is a shot of my rear end with delrin links http://i562.photobucket.com/albums/s...1080918531.jpg |
11-08-2009, 08:29 PM | #12 | |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
11-08-2009, 08:32 PM | #13 |
01-05-2012, 06:02 PM | #14 | |
Quarry Creeper Join Date: Nov 2011 Location: Maryville
| Re: Lower link rod ends Quote:
Chris | |
01-06-2012, 08:25 AM | #15 |
Rock Stacker Join Date: Nov 2011 Location: Pleasant Grove, AL
| Re: Lower link rod ends |
01-06-2012, 08:44 AM | #16 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
well, good thread necro guys.....doubting jeepial will deliver, seeing as that he, ya know, isn't a vendor or anything. raven, the 1942's are shorter than stock losi ends, by quite a bit. if you want to fix the issue once and for all, make your own links with revo ends. then you have a rock solid end, bigger threads holding it in, and links made to your specs. the traxxas 1942's will hold a 4-40 on a shock, but dunno about 5-40, never tried it.
01-06-2012, 08:47 AM | #17 | |
Chris | |
