11-11-2009, 10:00 AM | #1 |
Newbie Join Date: Sep 2009 Location: roseburg
| motor getting hot
on my lcc im running the xceleron 17.5 with a 12t pinion and motor is getting pretty hot after about 20 mins of runnig is there anything i can do to help lower the heat. the heat droped a little when i changed the pinion gear from a 15t to a 12t but still getting pretty warm
11-11-2009, 10:19 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: B.C. Canada
fan helps a little
11-11-2009, 08:32 PM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: Iowa
Lotsa worm lube and use the DIG to relieve the drivetrain pressure and not the motor to power thru it....you will be surprised at the difference it makes.
11-11-2009, 11:13 PM | #4 | |
Rock Stacker Join Date: Jun 2009 Location: Singapore Bukit Batok
New to crawler. | |
11-12-2009, 09:27 AM | #5 | |
With my brushless 18.5T Novak Crawler motor, I can rip 10 pound boulders out of the course with a squeeze of the throttle but the motor doesn't like it, nor do the axle pins. Using the "dig" to take the pressure off the drivetrain will not only lengthen your run times, but your motor will thank you for it. | |
11-12-2009, 10:46 PM | #6 | |
11-13-2009, 07:37 PM | #7 |
Rock Stacker Join Date: May 2009 Location: chattanooga, TN
Using the dig is going to help you the most, but I put a little computer fan on mine, and that keeps it cool for a bit.
11-17-2009, 07:58 PM | #8 |
Pebble Pounder Join Date: Nov 2009 Location: ft collins
make sure there is air movement around motor. try moving things if possible to get air to go in and out of the motor
11-17-2009, 10:57 PM | #9 |
11-17-2009, 10:58 PM | #10 |
11-18-2009, 12:34 AM | #11 | |
The DX3R has a 3P switch. | |
11-18-2009, 07:03 PM | #12 |
Newbie Join Date: May 2008 Location: US
Does the 3PK have a 3 position switch? I was hoping to use it for my Losi build.
