12-14-2009, 07:06 PM | #1 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| need a lil help
ok i have a lcc with sidewinder ana 35 turn motor an 1320 lipo . it will start to crawl up the wall an then just stops like the sidewinder is in thermal shut down . if u pick it up it will restart again . do i not have enough batt or not enough motor
12-14-2009, 07:22 PM | #2 |
Pebble Pounder Join Date: Oct 2009 Location: Chattanooga
| I would be curious about which pinion you are using, but I would have to say that you are getting worm stall. Try it again but when it acts like it wants to quit, dig with the front and see if it unbinds.
12-14-2009, 07:25 PM | #3 |
im running like a 12 or 13 on it an i cant dig rite now i have a 225 hitec an i guess i need a bec cause with both servos pluged in the sidewinder want arm till i un plug on of them
12-14-2009, 07:29 PM | #4 |
| Get a BEC so you can dig and then you'll be fine. With that pinion worm stall should be minimal but will almost always be present to some extent on the LCC. Also a little more motor wouldn't hurt.
12-14-2009, 07:37 PM | #5 |
thanks man im a ax 10 guy an now trying the lcc an it has already tested me bad lol
12-14-2009, 07:42 PM | #6 |
Pebble Pounder Join Date: Dec 2008 Location: Lake County
X2 on the BEC,seems like the extra voltage draw of multiple,or high torque servos can trigger a low voltage cutoff untill the rig is lifted and the servo centers.
12-14-2009, 08:06 PM | #7 |
12-14-2009, 08:45 PM | #8 |
well i dont want to go through all the probs if i dont have to lol
12-14-2009, 09:24 PM | #9 |
Rock Crawler Join Date: May 2009 Location: Calgary
I had the same problem with my LCC until I installed a CCBEC. Then the problem went away. |
12-14-2009, 09:46 PM | #10 |
guys i will give it a try
12-15-2009, 11:30 AM | #11 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
Yes yes Put a good BEC on it that will fix your problems.
