12-23-2009, 03:58 AM | #1 |
Newbie Join Date: Dec 2009 Location: Misawa, Japan
| Pinon Gear not included
Hello All, I just recieved my LCC (first rock crawler) and electronics. I was surprised to find you do not get a pinon gear with the kit. I have searched/reviewed many posts about suggested pinon's but nothing really says what pitch it has to be (I'm assuming 48P). Sorry for the dumb question, if someone can give me a little insight it would be greatly appreciated. thanks |
12-23-2009, 05:39 AM | #2 |
Rock Crawler Join Date: Sep 2009 Location: In West Monroe,LA...yes,where Duck Dynasty is filmed
yep 48 pitch ranging from 12 to 17.I started running a brushed starter boz motor with a 12 tooth then changed to a brushless 18.5 with a novak crawler esc for a 2s lipo,but am going to go up to a 15 tooth for more wheel speed.There are plenty of threads in here about that subject.Enjoy your LCC,i know i do |
12-23-2009, 06:38 AM | #3 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
Yes it's a 48p. As for the tooth count it just depends on your motor of choice. I ran a 35t warrior with a 15t, didn't have enough wheel speed, motor got hot, and run times sucked. If your gonna stay shafty, brushless is the way to go.
12-23-2009, 07:40 AM | #4 |
Thanks for the help
12-24-2009, 11:34 AM | #5 | |
Pebble Pounder Join Date: Jun 2006 Location: Keizer, OR
12-26-2009, 06:10 AM | #6 | |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
I would only suggest about 14 or 15 to keep the motor running cool...20 sounds like it would heat it up. This is just a guess and an assumption from what I have read. If you try it, let us know although I wouldn't want that much WS, just a tad more than the 13 gives. I would go 15t at most. Oops...I am running 3S...maybe the 2S is much slower than mine so I guess I'm not comparing apples to apples? Last edited by mascman; 12-26-2009 at 06:12 AM. | |
12-30-2009, 04:31 PM | #7 |
yeah, a $3 pinion is easier to experiement with than a $30+ battery. 21.5 with a 13t pinion is just too slow with 2s
12-30-2009, 10:34 PM | #8 |
i run a 12t pinion with my 18.5t goat and its awsome (i run 8.4 volts) but it could use a touch more wheel speed from a 13t or more volts
12-30-2009, 10:49 PM | #9 |
RCC Addict Join Date: Aug 2009 Location: Earth?
A 15T would be pushing the limit. A 20T would just be way over the top. Unless your just driving it on a ice hockey rink.
