12-27-2009, 09:37 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Ottawa
| adding weight
I received my LCC yesterday and went through the gears , greased them , and broke them in . Took tire off the rim and neither stick weights fit . Where are you guys puting the weights ? I have Losi and think Dubro weights . Neither fit into the rim inside the ridges . Looked at putting them on the inner side of wheel but won`t fit there as well . Appreciate any help . |
12-27-2009, 09:41 PM | #2 |
i put mine on the wheel above the ridge and trimmed the foams a hair to make up for the weights thickness
12-27-2009, 11:04 PM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: Iowa
I melted fishing weights in a pan on the stove, then let it cool as a strip along the edge of the pan. (DO NOT reuse pan for food!!) I then worked the cooled lead with a hammer to achieve a uniform thickness and a width that would fit into the LCC wheel. Once complete with the "blacksmith" work, I formed the lead around the wheel then used black tape to tightly wrap around the lead. On the rear wheels I re-drilled 2 vent holes thru the lead that matched the openings in the wheel. I did the same with the front wheels, except I drilled 2 extra holes because the front wheels don't vent as well with 8oz of lead. I even balanced them with a prop balancer for my RC airplane....but I don't think that really matters. |
12-27-2009, 11:07 PM | #4 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Wierd.... My lead fits perfect
12-28-2009, 12:06 AM | #5 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
I used a spool of solid fishing lead. Bends around the wheel nicely.
12-28-2009, 06:25 AM | #6 |
Newbie Join Date: Nov 2009 Location: eastridge
Try finding some different size weights. You can try any auto service that changes tires. That is where i found mine. They should have all different sizes.
12-28-2009, 12:20 PM | #7 |
Newbie Join Date: Nov 2009 Location: Logan
Most of the tire shops around here only have the steel weights which are to wide to fit in the wheel groove. If you can find the lead tire weights, they fit perfect. Rich |
12-28-2009, 12:27 PM | #8 |
Rock Crawler Join Date: Aug 2008 Location: Wine Country
The only weights I have seen fit the stock wheels are the associated ones and they are too much $$ for me. I ended up trimming the great plane's to fit.
12-28-2009, 12:31 PM | #9 |
Pebble Pounder Join Date: Oct 2009 Location: Chattanooga
Mr Gasket brand weights at the parts store fit inside the ridges fine.
12-28-2009, 12:41 PM | #10 |
Pebble Pounder Join Date: Sep 2009 Location: spearfish,sd
I used stick on wheel weights inside the wheel. I used 1/2 oz weights broke them apart and squeezed them with a pare of pliers and thay fit right in. you can get 5 oz in that way and for more i just stacked the weights. |
12-28-2009, 01:19 PM | #11 |
Pebble Pounder Join Date: Oct 2009 Location: Rapid City
I used these weights http://www3.towerhobbies.com/cgi-bin...P?I=LXK204&P=8 running the long way they fit perfect in my nightcrawler.
12-28-2009, 02:43 PM | #12 |
