12-30-2009, 08:20 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: virginia beach
| binding????
have a losi night crawler prettymuch stock cept for weights and such whenever i turn while on the gas it seems like excessive binding in the drive train is this normal?? shouldnt most of this be eliminated with the wormgears??
12-30-2009, 08:44 AM | #2 |
Newbie Join Date: May 2009 Location: Lorain
Is your battery fully charged? do you have the lipo? does it do it only when in a bind?
12-30-2009, 08:51 AM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Rocklin
Does it matter which way you are turning? How much you are turning? Forward or Reverse? High torque turning or even on a sidewalk? |
12-30-2009, 09:18 AM | #4 |
I am having a bindind/chattering coming from my night crawler when i try to climb incline with both front tires with traction it will just stop i have charged/balance my batt. only mods r 3oz in front and 2oz in rear 7998tg servo
12-30-2009, 09:37 AM | #5 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
| Check your epa's on your radio and make sure the tires are not rubbing the links at full turn? You should expect a little drag and notice it more on hard flat surfaces. Your fully locked front and rear. But if tires are rubbing links, you will notice it everywhere. I can't remember if the losi controller has end point adjustment or not.
