Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: BL temp ??
Old 02-14-2010, 05:01 PM   #1
Default BL temp ??
What is a normal operating temp of a Brushless motor set up do you run on your Lcc ? What is the max you've ever run it to ?
Lowe's48 is offline   Reply With Quote
Old 02-14-2010, 05:29 PM   #2
160F is ok.. when you start getting above that You can start destroying the
magnet..
fa1rch1ld is offline   Reply With Quote
Old 02-15-2010, 03:18 PM   #3
Mine runs around 130 when worked hard 21.5 turn on 3S with 13 tooth pinion.
Biohazard is offline   Reply With Quote
Old 02-15-2010, 03:22 PM   #4
ya never really want to get a lot hotter than 170 or 180. I ran my on-road car on brushless and would get around 200 If I pushed it hard without a fan, but a tiny little novak fan keep her cool around 150 or so!
Getting a fan is a wise investment on a brushless motor and they hardly draw any power at all!
jcboof is offline   Reply With Quote
Old 02-15-2010, 03:24 PM   #5
so maybe a little help, I dont have my temp gun in my Temp duty station. But i did just install a 17.5 novak motor, mmp and 12t pinion. After a pretty good run i can still hold my finger to it for 6 seconds. Odd question but approx what temp do you think i'm at?
xgerstandtx is offline   Reply With Quote
Old 02-15-2010, 07:58 PM   #6
im GUESSING 120-140
KrawlerKing is offline   Reply With Quote
Old 02-15-2010, 08:09 PM   #7
Thanks man, I was leaning towards the 140 mark so i am pretty comfortable with this thing. I ran 2 batts through it today on some super mild rocks and was about the same temperature. I am happy with it and the wheelspeed, torque is about spot on. thanks again
Old 02-15-2010, 08:11 PM   #8
Sounds good to me! If you can't hold your finger on it for more than 2 or 3 seconds, then its too hot! 6 seconds is about spot on for 130-140*
Old 02-15-2010, 10:08 PM   #9
I float around 160 ish after hard running, after a comp course maybe 130s.
bustedcrawler is offline   Reply With Quote
Old 02-17-2010, 08:32 AM   #10
Yeah that should be fine! I usually ran around 130ish, but I do know that it will start to stall around 180, and self destruct around 210!! That only happened once when I first got it with the bad worms and NO grease!
debooffroad is offline   Reply With Quote
Old 02-17-2010, 08:12 PM   #11
Mine runs around 130- 140ish after a 8.4v 1500mah and a 7.2v 1500mah so around 35-50 mins of run time on usual steep slick rock, meany climbs and few bind ups.
I'm running an 18.5t goat with a 12t pinion works great
2500hdon37s is offline   Reply With Quote
