02-24-2010, 10:11 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: Wa state
| 3s Goat w/o fan?
Novak recommends using the fan when running 3s on the Goat. Is anyone running 3s "without" the fan? What temps are you getting? The fan makes the set-up so tall it's kind of a pain to mount in different places. I've never run without it yet, just checking if anyone is braver than I? Thanks. Jug |
02-24-2010, 10:25 PM | #2 |
RCC Addict Join Date: Apr 2004 Location: 5280
I ran it that way for a while, and well in the end only had 2 blades with 1 more sorta attached. Not a big deal in winter, in summer I'd say you need it for sure. Really it's not that tall, so just mount it and forget it. |
02-25-2010, 02:50 PM | #3 |
I don't use it, but I run a 2S lipo pack, and I don't use an external BEC. The HiTec 7950 servo is likely drawing a lot from the internal BEC and this makes the controller fairly warm, around 120 degrees up to maybe ~140 last few times I've taken the temp after a run.
