03-16-2010, 09:40 PM | #1 |
Newbie Join Date: Mar 2010 Location: san diego
| pinion size help
hey i have a lcc with a 21.5 brushless exceleron, and i am running a 21 tooth pinion... after reading alot of post it seems like a 21 tooth pinion is high... should i get a new pinion. will this pinion cause damage to anything? thanks for any help |
03-16-2010, 10:11 PM | #2 |
no talent hack Join Date: Feb 2007 Location: Redwood City
a 15 tooth is perfect for the 21.5
03-16-2010, 11:19 PM | #3 |
Rock Stacker Join Date: Oct 2009 Location: Sumter
i would take a bet right now that your motor temps and your esc is quite HOT after a good 10-15 minute session. thats quite a bit of stress. 15 as said above is perfect match
03-17-2010, 12:10 AM | #4 |
Newbie Join Date: Oct 2009 Location: Spokane, WA
I'm using a 16 tooth with Losi's 3S crawler battery and it works great. No heat issues even after hard bashing.
03-17-2010, 01:06 PM | #5 |
Pebble Pounder Join Date: Mar 2010 Location: Morristown TN
Im running a brushed 55 turn with a 2 cell lipo and a 12 tooth pinion. After 15 minutes of running today the motor temp was 180 and it started to loose power and wouldnt hardly climb. Is this because of the high temp and am i running the proper pinion?
03-17-2010, 02:30 PM | #6 |
Newbie Join Date: Feb 2010 Location: Corinth, TX
I was running a 13 on my goat 3s 21.5T on a 3s lipo and it got pretty hot... i changed pinions till I found one I like. 16 tooth works best for me and I can run it at my LHS for 24 minutes with the 1500mAh battery and it never gets more than warm. i can put in a second pack and go another 20 min or so and hever have a problem. so i guess there is a thing as geared too low.
03-17-2010, 05:14 PM | #7 |
| your problem is the 55t is way to slow u need a 35t
03-17-2010, 05:22 PM | #8 |
RCC Addict Join Date: Aug 2009 Location: Earth?
15t
03-17-2010, 07:57 PM | #9 |
Newbie Join Date: Aug 2009 Location: Hagerstown
I am running a 35t motor and a FXR with a 14 tooth pinion . I think it is a 48 pitch pinion but what should I be running , I want good speed and not hot on the motor and ESC Please I cant find out what pitch to run and what the best pinion tooth to run HELP PLEASE !!!!!! |
03-18-2010, 11:48 AM | #10 |
yes its 48p and u should run a 12t or 13t no higher
03-18-2010, 11:13 PM | #11 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
15t i have the same setup
