04-11-2010, 07:08 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Tucson
| 27t motor on stock LNC ESC?
I did some searching and found a few people that seemed to be running a 27t motor on the stock LNC ESC, but no solid info on that setup. Can anyone tell me if that will work fine or not??? Thanks |
04-11-2010, 07:17 PM | #2 | |
Pebble Pounder Join Date: Nov 2009 Location: Utah - Rocks Are EVERYWHERE
I saw one sitting on the counter at my LHS with a 27t in it... I think you're fine... But read through your manual and see if you can find specs on the ESC. | |
04-11-2010, 07:44 PM | #3 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
i'm running a 27t in mine, with a stock can it ran hotter than all get out, but with a modified can set to 0, it runs like a champ, cooler than the steering servo infact.
04-11-2010, 08:14 PM | #4 |
Rock Stacker Join Date: Dec 2009 Location: O.C.
I was running a 27t on the stock esc. The manual says you could run a 12t. My experience with this set up was ok. I had more power, but it did not react well when I added more weight. It would run about 5 to 7 mins before it got so hot that it lost power. Thats with a 14 tooth pinion. And at that size of pinion I was back to my stock wheel speed. After experimenting with several different gear ratios I am now back with my stock motor. The low speed control on the stock motor is way better than the 27t and my run times have increased. The esc and motor don't even break a sweat. I was going for more wheel speed and at the same time trying to keep my torque. I have found that this probaly impossible with the LNC unless you go brushless.
04-11-2010, 08:23 PM | #5 |
Thanks for all the info. I had looked through the manual but I must have missed it. I think I may give it a try and see what happens! |
04-12-2010, 06:33 PM | #6 |
Newbie Join Date: Mar 2010 Location: Rome
I've also tried some different set ups and played with different pinions with the stock motor and I've concluded that I like the stock set up the best. Your not gonna win any drag races but the torque and slow speed control is excellent. The stock ESC does have a tendency to get hot even with stock motor and larger pinion gear. |
04-12-2010, 11:05 PM | #7 |
I run a 20t pinion on my 35t Integy and the can can heat up a little but I get great torque and wheel-speed. Plus I think the motor was around $17 After I go to a 3-cell lipo I might gear down a little... Anybody know of a pinion gear "variety pack" ? Something like a 17,18, and 19 in the same bag? |
