Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Kahuna's Build
Old 04-13-2010, 08:59 PM   #1
Default Kahuna's Build
I thought it was time to finally post up my Losi after a sad failure with the cast Bullys. The Bullys were bullet proof just to heavy for me.
Thanks to all the previous builders this rig was by far the easiest to tune and build.
Here's the specs
Hitec 7950 for steering
Kopro 949 for dig
MMP
CC BEC wired straight to the servo
1" SLW .675 / .475
Novak 21.5 17t pinion
Lungsford Links and Steering
NW Traction hybrid reaches soft fronts/firm rears (lol firm rears)
Losi shocks 32 1/2 front / 22 1/2 rear 15mm / 11mm
Panther Cougars
The rest is mostly stock, no need to upgrade.
Here's the pics
With body
and now naked
rear articulation with the shocks inverted and not binding
Close up of the lower shock mount
Shot of the lead tape rap I'm trying for a static mount on the axle
Kahuna77 is offline   Reply With Quote
Old 04-13-2010, 09:21 PM   #2
you have any problems with the 7950 wired to the servo? I had mine hooked up that way runnin 7.4v to the servo and the servo would spaz out whenever the front tires were up against a rock
samdog is offline   Reply With Quote
Old 04-13-2010, 10:18 PM   #3
how is yours setup?
I have both earth and hot leads from the BEC to the servo and only the signal wire is connected to the Rx.
No glitches yet, knock on wood though.
Old 04-14-2010, 04:42 AM   #4
Originally Posted by Kahuna77 View Post
how is yours setup?
Yea thats the way i had it hooked up, So i set cc bec to 6.0v and ran it thru the rx and no glitches, not sure if the servo didnt like the volts which its rated for 7.4v, It was a major headache for me Good luck
Old 04-14-2010, 05:16 AM   #5
Looks good.
wrightcs77 is offline   Reply With Quote
Old 04-14-2010, 09:12 AM   #6
Hey Sean,
Lookin good. You are correct about your Bully weighing too much. I think that you might want to try a battery with a higher c rating as the Losi will probably puff up that 20c batt.
Are you going to Teds with this truck on Friday? Do you have a MOA kit for it yet?
Kevin
Krawler Kev is offline   Reply With Quote
Old 04-14-2010, 10:01 AM   #7
Originally Posted by Krawler Kev View Post
Hey Sean,
Ran this for a bit, as long as I don't run them past the 10m mark they seem to be holding up.
Still deciding if I will convert them into 4s like my other cells
Should be there on Friday.
Old 04-14-2010, 10:46 AM   #8
what chassis is that?
sierradmax is offline   Reply With Quote
Old 04-14-2010, 10:57 AM   #9
Stock
Old 04-14-2010, 06:12 PM   #10
losiking1's Avatar
nice build, man. i'm running my 7955 servo wired the same at 6.5 volts and no issues yet either.
losiking1 is offline   Reply With Quote
Old 04-14-2010, 06:28 PM   #11
This rig works very well. Some really neat stuff done to it which seems to make it a little more agile while still being very stable. With a little more work this might be a very hard to beat truck, regardless of the driver, lol.
Scottmisfits is offline   Reply With Quote
Old 04-30-2010, 12:14 PM   #12
Figured I would update the build
Steering works for now, but I need to pick up some stainless
I call her the O.D.B. Chassis.
Wanted something with a high break over clearance
Bodies is alright, may change it out after I get back from Australia
Lastly the flex shot
