04-26-2010, 04:27 PM | #1 |
Pebble Pounder Join Date: Mar 2010 Location: Danbury
| Is this worm stall...
Hello everyone, Every now and again when I am crawling I get a motor sound like a high pitched squeal, not very loud but noticable. It happens when I feather the throttle and the truck does not move (a mild hesitation, then movement happens). Now this does not happen in a bind it usually just happens under some stress (tough, steep accent) So I will throttle the transmitter and instead of getting a response out of the motor (movement) I get a squeal/whine/hesitation/movement. I am concerned because I just got a new ESC after the last one caught fire. Is it possible that my motor has an issue? I have checked for binding in the system, its non-existent (worms are cut right, shims are good). The worms move smoothly, and are well greased. The mesh is, if anything loose. But it still seems like it, almost binds... I am a little lost for words, beacause I am new to electric, being a nitro guy. My real problem is I have a concern with the rig maybe having a defect somewhere and the esc is gonna blow up again. Is it possible that a brushless motor is faulty like this, causing these problems. BTW the rig is a LCC obviously, with the Losi Excelorin 21.5 crawling system. A Spectrum dx3e, and 3s 11.1v lipos. Thanks for the help, Ryan |
04-26-2010, 04:37 PM | #2 |
sounds like your slipper is loose
04-26-2010, 04:44 PM | #3 |
Pebble Pounder Join Date: Feb 2009 Location: LeMars, Iowa
Just going to throw this out there...had a similar squeal/squeak sound on initial throttle application, turned out I had over tightened the wheel nuts. Basically what was happening for me was that the hex's were pushing back on the outer axle bearings. Solution was to get new nylon nuts and make sure I put the small washer back between the bearing face and the pins after I tear down/lube the axles.
04-26-2010, 04:50 PM | #4 |
2500 thank you for the feedback: Slipper is pretty tight, and I know what that sound is. WARMACHINE: The wheel nut thing, how do I test this, maybe spin the axles, something along those lines? Thanks, Ryan |
04-26-2010, 04:58 PM | #5 | |
The thing that has me wondering though is that you said the gear set feels loose. If you get right down next the axle when it make the noise you might be able to pin point if the noise is starting centrally (worn gears would be my guess), or if it seems to be coming from out on the ends (hex/bearing rub). | |
04-26-2010, 05:16 PM | #6 |
i know mine screeched when i had a boken hex pin
04-26-2010, 06:12 PM | #7 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
04-26-2010, 06:35 PM | #8 |
04-26-2010, 07:11 PM | #9 |
O.K. this is great feedback, but would I notice a broken pin by spining the axle by hand. I think I would, no? If its possible that I would not notice that then maybe its a broken pin... I just am jumpy after cooking that last esc that its the motor causing the problems. I literally had flames, not fun. Ryan |
04-26-2010, 07:20 PM | #10 |
You should not be able to spin the axle by hand on an LCC. If you can, then something is broken in there. Can you spin one wheel individually while the other does not spin? |
04-26-2010, 07:59 PM | #11 | |
04-26-2010, 10:27 PM | #12 | |
Rockin' in Reno Join Date: Mar 2010 Location: Reno
04-27-2010, 04:47 AM | #13 |
I screwed up! I did not mean the axle, I ment the drive shafts comming from the tranny to the worm housing. Just for everyone who is helping me I can spin those, but I cannot spin the wheels to make the tranny move. Jackson, did you stick with the Excelorin ESC? Thanks Ryan |
04-27-2010, 09:09 AM | #14 | |
05-05-2010, 11:41 PM | #15 | |
RCC Addict Join Date: Dec 2005 Location: Tucson
My new motor makes the same sound. Dont worry about its normal Last edited by Flyin Hawaiian; 05-05-2010 at 11:59 PM. | |
05-06-2010, 08:46 PM | #16 |
Rock Crawler Join Date: Apr 2009 Location: NorCal
I think what your hearing is the brushless motor stalling a bit befor it starts to turn,,,not to worry but dont stay in that part of the throttle curve for long
05-07-2010, 07:39 AM | #17 |
For some reason the losi motors have this problem. But del monte lcc makes no noise at all smooth and even in a bind. So idk what the deal is with the losi motors but im going to try a tekin 21.5 or 17.5
05-07-2010, 07:45 AM | #18 |
05-07-2010, 09:39 PM | #19 |
thats what i was thinking but didnt ask him
05-09-2010, 02:10 PM | #20 |
This is intriguing about the HD worm gears. I think it would be worth it if this is true...
