11-18-2010, 11:15 AM | #81 |
Well, I quick call to CKRC and the correct part is on it's way.... |
11-18-2010, 02:25 PM | #82 |
good to hear as the hr is only good for looks and a wee bit more heat dissipation
11-18-2010, 02:37 PM | #83 |
Yeah.....IMO, HR stuff is only ever good for looks. I've had nothing but problems with their stuff that I actually need to perform a function. I remember getting this part in and looking at those purple things and thinking "wow, I dont remember this being in the picture..." |
11-18-2010, 02:45 PM | #84 | |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
11-18-2010, 07:14 PM | #85 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Guys, we will have more in stock soon, please order from us and you'll be sure to always get the real deal.
11-18-2010, 08:00 PM | #86 |
11-18-2010, 10:35 PM | #87 |
They will be in stock monday. CKRC was also out of stock, thats why they pulled the switcheroo. Horrible business practice if you ask me. Your LCC is looking good, keep it up! |
11-19-2010, 07:07 AM | #88 |
11-20-2010, 01:04 PM | #89 |
Well, pretty damn fast shipping from CKRC..... |
11-21-2010, 02:17 PM | #90 |
Well, I finally picked up an accurate scale from a restaurant supply store so that I didnt have to weigh my truck up at work. This new setup (the one pictured above) comes in at 5lbs 4.5oz.....not to shabby/flabby.... After a bit more measurements, I get the following numbers for weights at each corner: Driver Front: 1lb 7.8oz Pass Front: 1lb 8.0oz Driver Rear: 1lb 2.4oz Pass Rear: 1lb 2.7oz Front total: 2lb 15.8oz = 3.0lbs Rear total: 2lb 5.1oz = 2.3lbs This means that the weight bias is about 78% toward the front. However, it looks like my driver side is slightly heavier than the passenger. I dont think it is enough to make a difference and would certainly be easy to fix by moving a few electronics around. Wow....two posts, two completely different crawlers, almost the exact same results....... |
11-29-2010, 04:35 PM | #91 |
I've been enjoying driving this thing lately. I picked up some of the D-Lux knuckle weights and got them installed: These are VERY nice pieces. Everything went together well and easily. You will need to grind a hair off of the front of the C (which I have not done yet). I'll put some runtime on these this week... |
11-29-2010, 06:03 PM | #92 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Cool How much weight were you able to add with those knuckle weights? |
11-29-2010, 06:37 PM | #93 |
About 3.3oz per wheel. With the weights you see in the picture, they can be setup for either 2.3, 2.8 or 3.3 oz.... |
11-30-2010, 12:21 AM | #94 | |
RCC Addict Join Date: Jan 2010 Location: Lafayette
Regardless, nice round of tuning while I've been away dude! Glad you are liking it. If I was to do it over again(probably more of a "when") I'd only use the hard spur and slipper delete. I'm not happy with all steel in the tranny. Noisy and heavy. And don't try the alum dig plates either, plastic is superior. | |
11-30-2010, 05:24 AM | #95 |
Quarry Creeper Join Date: Aug 2009 Location: Heilbronn/Germany
How do you like the shocks? Where to buy?
11-30-2010, 06:47 AM | #96 |
Those shocks are BY FAR, the best I have ever used. They are MUCH smoother than the Traxxas Bog Bore and they dont leak a drop. I get them from Amain: http://www.amainhobbies.com/product_...-Cap-Shock-Set However, you might have to find them closer since I dont think they'll ship to Germany... |
11-30-2010, 07:04 AM | #97 |
| Good catch Shell! The front weight should be divided by the total weight. Now (with the knuckle weights), the numbers should be as follows: Front total: 3lbs 6.4oz = 3.4lbs Rear total: 2lbs 5.1oz = 2.3lbs Which gives a front bias of: 60% Glad you are back! Yeah, I am happy with the tranny setup now....no more broken parts. I do, however, keep breaking CVD pins....got a set from Gunnar on the way. |
11-30-2010, 01:10 PM | #98 |
Newbie Join Date: Nov 2010 Location: Dalton
So what should we be shooting for with weight bias? 60% front and 40% rear or is there a better number to shoot for?
11-30-2010, 01:19 PM | #99 |
That is really a preference thing.....not one answer will be correct. Personally, I like to have the balance point (of all of my trucks) located right where the front lower links attach to the skidplate at the chassis.
02-25-2011, 08:49 PM | #100 |
I finally got a good ESC for this thing: And this truck brought home the big ribbon at its first outing. |
