08-04-2010, 09:21 PM | #1 |
| Night Crawler rear drive shaft grubs stripped
Ok what is the trick to getting these things out? I want to replace the rear worm. I was going to break out the drill and then I decided that I had to step away for moment. I tried heating it with a soldering iron, no good. Thanks |
08-05-2010, 07:35 AM | #2 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
If you mean trying to get the driveshaft out, I can leave my driveshafts in it when I pull my axles apart. I just unbolt the axle from the crawler then pull the driveshaft out of the tranny and the driveshaft is still attached to my axle and then I just pop her open.
08-05-2010, 07:48 AM | #3 |
Sorry I did not explain it well enough. I have already taken the axles apart and where the driveshaft attaches to the worm gear is my problem. I have a new set of worms that I would like to put in and the screws that go from the driveshaft to the worm gear are stripped out.
08-05-2010, 01:52 PM | #4 |
take a cutting wheel on a dremel and cut you a line to use a small flat head screw driver
08-05-2010, 04:42 PM | #5 |
Pebble Pounder Join Date: Oct 2009 Location: in a state of labyrinth
You may try the next size hex wrench or the next size standard allen
08-05-2010, 10:59 PM | #6 |
08-05-2010, 11:02 PM | #7 |
