08-25-2010, 09:36 AM | #1 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
| Crawler Design Works - Losi Parts Thread
A quick introduction of myself. My name is Rob and live in Farmington NM, my day job is designing industrial equipment for a machine/fab shop. I have been working with Anthony (Yotachump) from nearly the beginning of CDW. We collaborate on all of the product designs and I do all the CAD work. Recently I traded in my berg for a pair of Losi CCR's. I setup the first one using Del Monte's setup and felt comfortable with the truck by the end of the first comp. I'm tickled to even be showing the bergs a thing or two . Only problem is that I can't leave well enough alone so be expecting some new CDW Losi products to be coming down the pipeline as I develop the second truck. I have upgraded to vendor status so that I can deal with these parts directly and any PM inquiries involving Losi parts should be sent to me not Anthony. While we dial in some of the designs, how about a feeler to gauge the interest in an Aluminum Hardware kit. Currently getting quotes for a transmission and chassis kit. Is there any interest in this? It would be considerably cheaper than having to piece it together for yourself. Last edited by rob_b; 08-25-2010 at 09:38 AM. |
08-25-2010, 09:48 AM | #2 | |
Quarry Creeper Join Date: Jan 2010 Location: Albuquerque
| sounds good!
How about an MOA kit that's not so bulky and comes with 48p gears? Quote:
08-25-2010, 09:52 AM | #3 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
I'll be keen to see what you come up with Not sure what your plans are but i would like to see someone make stainless C's & knuckles |
08-25-2010, 10:01 AM | #4 |
RCC Addict Join Date: Aug 2007 Location: Seattle
I'd like to see heavy C's myself. A true BTA setup would be pretty cool as well.
08-25-2010, 10:23 AM | #5 |
I don't see developing any MOA parts, a chassis at most. Removing as much rotating and sprung weight and adding it back on to the axles is defiantly one of the goals |
08-25-2010, 10:33 AM | #6 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
Definitely some weighting system similiar to DelMonte's would be great! Still looking for better clearance w/o the sacrifice of sidehilling.
08-25-2010, 10:47 AM | #7 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Hardware kit is a great start. My rig is working great! Curious to see what you can do to make it better IMHO about the only thing I'd change is less rotating mass, they say that helps alot. |
08-25-2010, 11:53 AM | #8 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
I'd be interested in aluminum hardware, if it was metric.
08-25-2010, 12:00 PM | #9 |
RCC Addict Join Date: Jun 2009 Location: California
Knuckles that can handle a better weight setup that would take away the mass rotation weight. Check Del's thread....He has the best idea so far. |
08-25-2010, 12:34 PM | #10 |
08-25-2010, 12:40 PM | #11 |
Yep...I like the fact Del uses the Losi after-market C's/Knuckles. GL on the designing..The Losi is a fun little rig. |
08-25-2010, 03:05 PM | #12 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Keep me posted on that chassis i would like to see some real high clearance links on the rear.
08-25-2010, 07:40 PM | #13 |
Quarry Creeper Join Date: Feb 2010 Location: Nevada City, CA
I like the hardware kit. Also anything you can come up with to achieve better ground clearence under the skid would be cool. That seems to be the area that the bergs really excel over my LCC.
08-25-2010, 08:11 PM | #14 |
How about some sealed axle housings so we can run oil instead of grease, I know it will probably never happen but it seems like a good idea
08-25-2010, 08:43 PM | #15 |
Quarry Creeper Join Date: Feb 2010 Location: Knee deep in a creek with a fish on the line
I like the idea of alum hardware. I would like to see the bent rear links as well. I know others sell a version but the dig servo mount you use frees up some space. The RC bros mount is nice but takes up some serious room.
08-25-2010, 09:01 PM | #16 | |
Quarry Creeper Join Date: Jan 2010 Location: Dearborn Hts
I have 2 complete LCC's and as soon as our Summer series is over I intend the put my main Comp rig on a diet.... | |
08-25-2010, 09:09 PM | #17 |
Like a boss... Join Date: Feb 2008 Location: NorCal
My only comment for you Rob is....where were you last year! Seriously...I couldn't be a bigger fan of CDW and the two of you. I'm sure what ever comes out your skunkworks will be awesome. Last edited by mann0mann; 08-25-2010 at 10:16 PM. |
08-25-2010, 09:12 PM | #18 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
Metal or alloy housings so we don't keep stripping out the plastic threads. When the worms are in a good bind, the force slowly but surely seperates the housing. I think this deflection contributes to worm gear breakage. Will also be in line with your goal of more unsprung weight. Might be a good way to ditch the wheel weights if it's heavy enough. A servo/battery tray for the front axle. Would probably need to be angled like this ^ to allow full steering throw. A lightweight delrin bodiless option designed to fit around rhe LCC tranny, preserve the double triangulation and shock/uppers hole options. A servo plate that allows increased tringulation on the uppers. |
08-25-2010, 10:45 PM | #19 |
Thanks for all the suggestions guys... Tweaking on Berg parts I figured with the XR10 coming out what better time to jump ship on the MOA thing and swim up stream with a shafty. |
08-26-2010, 06:47 AM | #20 |
Rob what about a weight system that fits inside the axle housing? This could go along with the alum housing idea.
