10-29-2010, 10:20 PM | #1 |
| Horrible rear pinion wear.
Ok i am running 15t 48 pitch losi pinion on the front of my crawler and i have been running 14t 48 pitch Robinson Racing pinions on the rear, i have stripped, or just about stripped 4 pinions on the rear axle and my losi pinion is still in good condition.Blc re-gears are wearing about the same, still on first set. Are losi pinions a harder material than the RR or could there be something wrong with my rear end. I have done the whole make the moa bracket parallel with the re-gear and set my mesh right so i'm not sure what to do next other than to order a losi pinion. pinions gears wear isn't to good on the motors either, it seems i clean shavings off of them all the time |
10-29-2010, 10:35 PM | #2 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
the losi pinions are a better material than the robinsons for sure.
10-29-2010, 11:36 PM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: Iowa
Robinson Racing pinions are junk. They are soft and the pitch is close but not quite right. I haven't worn a Losi pinion out yet....but made junk outta the RR ones in no time.
10-30-2010, 01:16 AM | #4 |
Ok so the RR pinions are pos. Is losi the best gears or is there better?
10-30-2010, 01:17 AM | #5 |
10-30-2010, 01:21 AM | #6 |
check to see if your MOA bracket is on there square/ level. you might have the gears meshing slightly crooked where they meet because of the MOA kit, i know Jeepial had to do a little shaving on his, but he got it to where his rig ran almost soundless in terms of gears making noise
10-30-2010, 02:34 AM | #7 |
Yea i leveled the moa bracket and blc re gear out, its about 1/2* off from level, It runs nice and quite with a new gear then it just gets worse and worse every battery pack, it kinda actually bends the teeth in a sense, almost curves them once it has wore off enough material then it just strips them out, i have seriously stripped 4 pinions on my rear, none on the front
10-30-2010, 11:11 AM | #8 |
then it almost sounds as if the BLC gear is out of round or wobbles on the worm pinion and thats causing the wear
10-30-2010, 01:31 PM | #9 |
Thats why you have to level the re gear with the moa bracket, because it only has a set screw on one side so it doesn't sit perfectly perpendicular to the axle when you tighten it.
11-01-2010, 04:56 PM | #10 |
yes, im aware, but made your bearings that hold the worm pinion are worn out and loose then?
11-01-2010, 04:59 PM | #11 |
| Now thats a complete possibility as well, i have a good year on the these bearings, But my front used to wear as well not as bad though. possibly another tooth so each tooth as a longer lifespan. I went to losi and it still looks good. So i am thinking its the pinion material itself.
11-01-2010, 08:17 PM | #12 |
I had horrible luck with the RR pinions. I wont run anything besides LOSI.
11-01-2010, 10:00 PM | #13 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
The losis seem to be stronger then most. I run all losi pinions an every crawler I have owned, when I go to sell them the junk ones from the kits go back on. They just are that good, that I cant stand to get rid of a 5dollar gear.
11-01-2010, 10:55 PM | #14 |
11-02-2010, 07:37 AM | #15 |
11-02-2010, 04:25 PM | #16 |
Quarry Creeper Join Date: Jan 2010 Location: Albuquerque
| switch
I'm switching back to the 32P gear set...
11-02-2010, 06:09 PM | #17 | |
I linked to a picture on my website that is only viewable to my club members. Here it is.... The one on the left is a standard pitch pinion that was inadvertently put in to my Berg by the former owner....the one on the right is a RRP pinion that I replaced it with.....before I figured out they take metric pinions. I ran the one on the left for about 4 hours, I ran the one on the right about 10 feet. Last edited by Mad Dawg; 11-02-2010 at 06:13 PM. | |
