11-10-2010, 04:24 PM | #1 |
Newbie Join Date: Nov 2010 Location: oxnard
| heat
i have a losi comp crawler and the drive shafts keep getting hot!!!!!!!! what can i do or use to cool it down.
11-10-2010, 04:49 PM | #2 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
What, sounds like you need to grease the worms LCC Tips and Tricks its a sticky check it out Last edited by hardhead; 11-10-2010 at 04:52 PM. |
11-10-2010, 04:52 PM | #3 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
They still get pretty warm though don't they? I have a very funny memory of someone picking a Losi up and getting burned by the front shaft. |
11-10-2010, 05:47 PM | #4 |
| Never seen none of my losi's get more than a warm feeling never hot. If i were to guess i'd say 115~120. I do have a nice temp gun,i'll temp the moa and the shaft and see..Grease my friend
01-06-2011, 09:11 AM | #5 |
Rock Stacker Join Date: Jul 2009 Location: RAPID CITY
grease your worms... |
01-06-2011, 11:06 AM | #6 |
definitely need greased. there was a pick of someones losi worm getting so hot it heated the bearings enough they melted through the axle casing
01-06-2011, 02:06 PM | #7 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
I am wondering if I need to grease my LNC before I run it. Anyone checked how much Grease is in the Stock Night Crawler before they ran it?? Mine should be here tommorow
01-06-2011, 03:23 PM | #8 |
they come with some grease, its just not enough or the greatest grease for the worms. so you should get some and pack it in there
01-06-2011, 03:58 PM | #9 |
What about the High Temp Red Grease they sell at Wal-mart?? I already have some of that stuff... I have used it in the Past with good success...
01-06-2011, 07:27 PM | #10 |
Pebble Pounder Join Date: Dec 2009 Location: Ottawa
Drill a hole in the axle housing and use a set screw as a plug so you can ad grease regularly . For grease , I have tried a few different brands and types . I found Silkolene RG2 to work the best while keeping the worms pretty cool . I can run for a couple of hours and never get hot . |
01-07-2011, 10:20 AM | #11 |
you can try the red grease you have as its likely better than whats in the axles now. just check the temps often and see how it does, and every now and then to see how well the grease works you may want to take the axles apart to check wear. if everything looks good over time then you will likely be fine with your current grease
