11-14-2010, 09:07 AM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Bismarck
| LCC setups what is everyone running on there shaftys.
What is everyone running for setups shocks, shock position, oils, tires, foams, wheels, how much weight in the wheels. Just lookig for different ideas. I have rcbos motor clamp, front servo mount, and dig mount to install. Also broke front cv got losi part # LOSA3196 for replacements are these the v3? Also got some losigold 1.4 rate springs to try. But need some opinions on wheel weight, and how to do it with stock wheels were to put the weight also.
11-14-2010, 09:39 AM | #2 |
Rock Crawler Join Date: Jun 2009 Location: summertown
try these three links if they aren't what your lookin for, try the search button it can be really handy odd are that someone has already asked this question. Wheel weight questions suspension setup? A thread about Weight EeePee Erik D_Lux Del Monte Robbob and RcBros also have some very detailed LCC threads Last edited by Twisted Nuts; 11-14-2010 at 10:10 AM. |
11-14-2010, 02:45 PM | #3 |
This is my current setup but haven't been able to use it. Front supension shock arm lowest hole c, shock mount hole 1, gold losi springs, 50wt oil, upper link in top hole. Rear setup upper link bottom hole, shock mount hole 3, shock arm middle arm B, factory white springs, and factory shock oil. Also have the rcbors front servo mout. Also going to be installing soon rcbros dig servo mount, and motor clamp. Have no weights in the wheels in the rear, about 3oz in the front with factory wheels tires and foams. Have my battery mounted on the front four link the radio on the rear four link, and the esc on the rear axle. Removed factory receiver mount and battery mount.
