01-11-2011, 01:17 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Grass Valley
| LNC TO LCC conversion help
got my lcc trans today just wondering if the lnc drivelines will work with the cc trans? thanks.
01-11-2011, 01:25 PM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
It should just bolt in!!! then get a 225 servo
01-11-2011, 01:29 PM | #3 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
Yes they will work. I've been using mine on my lcc/lnc hybrid for about 4 months now.
01-11-2011, 01:49 PM | #4 |
I have been using the LNC shafts on my conversion for an entire season, with no problem. I have killed 2 HS 225MG setting up my dig, soI just went full sized for the dig.
01-11-2011, 02:23 PM | #5 |
awsome thanks for the fast reply everyone going to get the futaba 4pl tomarrow. that should do everything i need i believe
01-11-2011, 02:54 PM | #6 |
i have my first comp this sunday dont expect much just want to not be dead last lol
01-11-2011, 05:03 PM | #7 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
01-11-2011, 09:14 PM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Hector
Good luck. Most important thing is to finish and not get a DNF. Anything past that is a bonus. If your radio has Expo dial in about +20% to +30% on your throttle. Helps keep the brain ahead of your crawlers driving speed. {very slow} steady pace . Keep us posted on how ya did. Once I dialed in expo and or used the ESC throttle curve setting , My capabilities got way better. Looking forward to competing now.
01-12-2011, 07:15 AM | #9 |
thanks for the words of wisdom i will definatly try to figure out how to do that on this radio. this thing does everything under the sun. i think i made a good choice "slow and steady wins the race"
01-13-2011, 05:36 PM | #10 |
Rock Stacker Join Date: Jul 2009 Location: RAPID CITY
u shouldnt have any problems using them |
01-14-2011, 08:17 PM | #11 |
Newbie Join Date: Dec 2010 Location: Modesto
I made the same mod the stock drivelines work fine.
01-16-2011, 08:13 PM | #12 |
WOO HOO!!!!! 2nd place on my first comp . the dig made all the difference . impossible without it
01-16-2011, 10:04 PM | #13 |
Newbie Join Date: Oct 2010 Location: venezuela
all i need to put a dig in my stock LNC its a 3ch radio, lcc trans and a servo? can i put the dig and use nimh batteries? no problems with the battery tray?
01-17-2011, 09:13 AM | #14 |
battery tray must go bye bye. get a 7.4 lipo. 16.99 ckrccrawlers.com use a battery strap to secure it to the steering servo. the reciever i just servo taped it to the inside of the chassis. worked Flawless all day....
01-17-2011, 09:15 AM | #15 |
Also ...your radio must have a 3 position 3rd channel with end point adjustments so you dont burn up your dig servo
01-17-2011, 10:56 AM | #16 |
how much runtime does i get from a 1200mah 7.4v?
01-18-2011, 07:54 AM | #17 |
i went through 4 comp coarses on one battery. about 5 min per coarse
01-18-2011, 01:17 PM | #18 |
Rock Stacker Join Date: Sep 2010 Location: Detroit Area
On a course it should work for most the day, but in the yard or bashing it will last 10 min or so depending how you drive.
