01-14-2011, 08:08 AM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Grass Valley
| lnc w/cc trans question?
lnc to lcc conversion pinion size? i plan on running the stock esc and motor. what would be the best pinion gear to run? i dont want to lose any torque. but want to gain some wheel speed from the stock lnc set up.
01-14-2011, 08:59 AM | #2 |
Newbie Join Date: Dec 2010 Location: Modesto
| Ratio's
Well the NC comes with a 20t pinion and with the NC trany that gives you a gear ratio of 62.5 to 1. That same size pinion in the CC trany gives you a ratio of 50 to 1 (more wheel speed less torque). So if you wanted to keep the CC trany same ratio as NC you need to run a 16t pinion to give you a ratio of 62.5 to 1. The higher the ratio you run the more torque you will have, but you will loose wheel speed. Since you are running stock NC electronics I would run a 16t or smaller. The ratios for NC are in the manual and the same for the CC. You can download the CC manual from Losi's website. |
01-14-2011, 09:31 AM | #3 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
I was running a 13 tooth and loved it.
01-14-2011, 09:42 AM | #4 |
i have an E-Maxx just sitting i was thinking of robbing one of the motors from that to put in the crawler. i have read that some people are doing that with mixed results. any input?
01-14-2011, 03:33 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
The LNC and LCC trans are two completely different setups. You will have to be very careful or you will burn up your stock LNC electronics. The LCC and its trans is built for brushless where the LNC and its trans was built to be able to run brushed systems. |
01-14-2011, 09:54 PM | #6 |
picked up a 16t pinion gear today going to try that first going to be alot of test and tomarrow before my first comp on sunday
01-14-2011, 09:55 PM | #7 |
i dont really want to spend alot of $$$ on this rig as i am in the middle building a moa as well
01-17-2011, 09:22 AM | #8 |
i had to run a 10t pinion. with a 35 turn integy i had laying around. the stock motor just didnt have it in it. lol worked good enough for 2nd place. i have nuthin for wheel speed. but plenty of torque. the dig works great also. thanks for the help evryone
