02-23-2011, 02:27 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Frisco
| 20 degree hub carriers--Disadvantages?
I've read a lot of good things about these hub carriers here. I'm just wondering if there are situations or types of terrain where they would be at a disadvantage compared to the stock 10 degree carriers. Seems like everything else, suspension related, is a tradeoff--you gain this but lose that. Are these the same type of deal? Thanks! |
02-23-2011, 03:34 PM | #2 | |
If there is a dis advantage i'm sure the advantages out weight it. | |
02-23-2011, 03:47 PM | #3 |
| Advantages are the only things I've been seeing as well, but since most of the suspension related physics have been around for a long time it makes me wonder why Losi designed the originals with 10 degrees of caster. Seems like someone must have had a good reason, no? (I have some 20's on order as well ) |
02-23-2011, 03:59 PM | #4 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
There are no disadvantages that Ive seen in running mine. I swapped back to the 10s to see if I was really liking them that well and I was. I could not pull off the same line without them. They really let the tire "reach out" and grab ledges extremely well.
02-23-2011, 05:28 PM | #5 |
Only thing I saw as a disadvantage is that while your one tire can reach out and grab a ledge it does the opposite with the other tire, it swings it backwards. There has been a copule times that I have been working a line really hard, get past a certain point, try to reach/ try to turn and it pushes the downhill tires backwards and forces me back into the same point I just worked hard to get past. This does not happen enough to give up my caster. |
02-23-2011, 06:22 PM | #6 |
Thanks for the responses! Great info. I was thinking there must be some downside to these but it sounds like any slight disadvantage is far outweighed by the benefits. |
02-23-2011, 08:02 PM | #7 |
I have liked running them, My LCC is a super belly dragger and it hepled me get a good bite on breakovers that were next to impossible in the past. |
02-23-2011, 10:33 PM | #8 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Only downside I can find is that my wallet is a weee bit lighter |
02-23-2011, 11:14 PM | #9 |
02-23-2011, 11:21 PM | #10 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
I guess a small disadvantage from what i understand is that this wil not work with the RCBROS highsteer kit. Which sucks since i really enjoy my histeer kit.
02-24-2011, 08:47 AM | #11 |
Quarry Creeper Join Date: Mar 2010 Location: Central NC
It will work with the RCBros OTA steering. Just have to do some minor work to the OTA link, I'm running the 20* hubs and the RCBros OTA. RCBros is working on a set of high clearance knuckles and new OTA steering link that are both designed for the 20* hubs. Here is a pic of mine with the RCBros OTA steering and the 20* hubs. Last edited by untchabl; 02-24-2011 at 08:49 AM. |
02-24-2011, 02:39 PM | #12 |
Very cool man. I'm glad you brought my attention to that. Did you end up filing the ends(towards the knuckles)? Just to lower the entire assembly down a little? I'm not excited to file any off of the top so using the ends would be way better.
02-24-2011, 02:49 PM | #13 |
Yes. You have to remove material from the bushing too.
02-24-2011, 04:30 PM | #14 |
Yes, and Killswitch is right, you have to remove material from the bushings as well. Been running mine for awhile now and it has been working great.
02-24-2011, 04:39 PM | #15 |
02-24-2011, 05:11 PM | #16 |
02-24-2011, 05:16 PM | #17 |
That is odd, I did not remove any material from the link, I had to file the front of the stock servo plate to get mine to work properly.
02-24-2011, 06:17 PM | #18 |
I'm running the RCBros LCG servo mount, haven't checked fitment with the stock servo mount.
