03-31-2011, 08:20 AM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: Massachusetts
| R/C Bros LCG steering servo mount issue
So, bought the R/C Bros LCG steering servo mount for my LCC. Got it put on, only to realize, it sits so low, that the nuts from the servo mounts hit the upper links. I've tried the Losi micro nuts, the stock ones, some little stainless ones I had around, and they all end up getting pushed into the rod ends if you tighten them down. I've shaved the back servo mount post down, tried using spacers, everything I could think of to get rid os this issue. The big difference being on the bottom of the stock servo holder, there are recessed parts for the nuts to go up into. So then I'm thinking, maybe it just won't work cause of the 20* hub carriers, cause it was also interfering with the servo horn. I threw it onto my LNC, which has the stock stuff, and still can't get the thing to mount properly. Am I doing something terribly wrong, or has this issue plagued anyone else? I like the product, the other stuff I got worked/fit perfect, and I've been more than pleased with William's customer service. I'm just lost on this one. -bryan |
03-31-2011, 08:35 AM | #2 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
Just use a dremel and take a little off the rod ends on the top side and everything will work perfect. I also used a button head screw from the bottom side of the servo plate and just put a washer and a nut on the top of the servo mounts.
03-31-2011, 08:37 AM | #3 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
03-31-2011, 12:56 PM | #4 |
god, talk about looking too much into the issue, i'm gonna go try that! thanks guys.
03-31-2011, 01:14 PM | #5 |
Pebble Pounder Join Date: May 2009 Location: farmington crawler capitol
im using the same servo mount with the aluminum servo mounts and i put the nuts on the top of the mounts and it works like a charm im even using 20 degree hubs and have no issues
04-01-2011, 09:37 AM | #6 |
Pebble Pounder Join Date: Dec 2010 Location: Midwest City
04-01-2011, 10:02 AM | #7 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Not sure how much meat there is on the servo plate but one option is to counter sink for a flathead. |
04-01-2011, 10:21 PM | #8 |
Rob_b, awesome idea. I did some quick measuring, and figure, since they can be countersunk form the top, it can be done from the bottom. I marked where the servo mounts go, countersunk some holes and used some stainless flathead bolts, with nuts on top. Thanks for the suggestion! -bryan |
