05-11-2011, 12:27 PM | #1 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
| Rubba's TLR Comp Crawler Prototype
Well, well, well.... Can you believe it? I've been working on a new set-up this year and need to share what I've been cooking up. I started out with the stock chassis, skid and links for this project. The main purpose is to create something for those peskey breakovers that are killing us from time to time. I turned the gearbox 180* from stock so it would hang out the side of the chassis. Making the driveshafts run down the center, instead of to the side. Next I cut out the side of the chassis where the motor will sit. It's very close to the edges but I have not had a problem with it. The gearbox will need to be raised up about a 1/8" to clear one of the old mounting holes that's right below the driveshaft. Next is the bent links . I took the stock front and rear lowers and bent them about 30-40*. Then for the rears I added a 3/16" spacer to each end. Front only needed one spacer. This is something you will need to play with to make sure it measures 12.5". Bending the links a little more or less will get you there. As for the ESC, I mounted on the opposite of the motor as far forward as possible. I had to cut out one of the supports so it would tuck inside of the chassis. *** Doing this set-up you want to make sure you support the gearbox from tilting. I mounted my RX between the gearbox and side plate of the chassis with shoe-goo. This wedged the gearbox and now it has no movement at all. *** |
05-11-2011, 01:32 PM | #2 |
Pebble Pounder Join Date: Apr 2011 Location: DOWN SOUTH!!*LONESTAR*
WOW!!! Sweet ride man. How did you 180 the tranny? Did you just spin the skid plate around. With the centered drives do you have a lot more link clearance now. Did you clock the front axle any? Good work you got there
05-11-2011, 01:41 PM | #3 | |
The motor now sits on the left side (drivers side) I do have the front clocked with 20* C's plus the stock upper link. This gets to be around 25* of goodness. The link clearance is very noticeable now. I giggle everytime I drive this! | |
05-11-2011, 02:00 PM | #4 |
About time you posted this!! I have been telling people about it and they look at me like I'm nuts!~Well nothing new there, but..... Use the macro setting on your camera, it does wonders! |
05-11-2011, 02:00 PM | #5 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
So the main reason for moving the trans is to center the drive shafts so you can run larger bent links...?
05-11-2011, 02:16 PM | #6 | |
All pics are taken using my phone, you know me, no PC, Camera or cool electronic stuff. I don't even have cable TV. I'm just a eco-green dork that recycles and loves Nature Yup, straight links dont have enough to get over the break-overs anymore. | |
05-11-2011, 02:40 PM | #7 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Chassis mods are cool... but its the stance of the truck/body that are just plain sick |
05-11-2011, 02:42 PM | #8 |
Nice dude. Beers. Oh hey, what hubs you running? OG DH wheels right? Not the new ones? |
05-11-2011, 02:43 PM | #9 |
What's your thought on a narrow version? Do you see need?
05-11-2011, 02:52 PM | #10 | ||
Yup OG hubs on the DH's, Front 585 V4 in the rear with 600's I thought about that but the upper links would hit the slipper and dig shaft. I wanted to keep the geometry in the perfect position and it's waaaaaay better then before. Change the geometry design and you start to chase other problems is the way I see it. Thanks for all the comments guys | ||
05-11-2011, 03:08 PM | #11 |
05-11-2011, 03:08 PM | #12 |
Rock Crawler Join Date: Oct 2008 Location: Italy
with new driveshaft position is tranny smoother, do you feel the truck is a little faster ?
05-11-2011, 03:22 PM | #13 |
05-11-2011, 03:36 PM | #14 |
Im still chasing the idea of spinning the tranny around. When you spin it do you simply just drill out the skid to make holes for the mounting screws since the skid only has the holes on the one side when it comes stock. Im really interested in doing this because Im tired of the shafts hitting the links so easy esp. when I clocked the front it gave me even less clearance.
05-11-2011, 03:40 PM | #15 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Looking good Rubba! Are you bringing that thing to WCC this year? |
05-11-2011, 07:44 PM | #16 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Edit: How is the durability of the nylon nuts? Do the threads still hold if you take them in and out a few times? | |
05-12-2011, 02:29 PM | #17 |
I thought this was gonna be like a pre-release proto type crawler (like moa). Anyways looks good |
05-12-2011, 03:02 PM | #18 |
05-12-2011, 07:19 PM | #19 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
| Here's a video from the Central States Challenge. |
05-13-2011, 08:40 AM | #20 | |||||
